Performance exhaust
Performance exhaust
Based on what I've read and researched we have limited options on aftermarket exhausts. All the ones I've seen are barely noticeable in sound. I guess the best bet is getting the HKS. All the others are similar to stock or not made for the use model.
Well you could go full custom cat back and also eliminate the resonator. That would probably be louder than HKS/TANABE/BISIMOTO which are all axle back. The BISIMOTO is supposed to be louder than the HKS/TANABE, from my research those two are around 92-93 decibels.
I'm happy with my HKS. Loud enough when I get on the throttle but hardly noticeable when cruising at 2000-2500 RPM.
If you've not already done so, head over to the Exhaust sub-forum and spend some time. I have the Tanabe Medallion Touring, and am very happy with it.
es
es
Which ones are you referring to that are not made for the 'use' (US?) model?
I recommend Bisomoto if free flowing and a louder sound is what you are looking for.
Good luck!
Forgot the Spoon: Spoon Sports N1 Axle-Back Exhaust - Honda Fit | KamiSpeed.com
But it almost looks exactly like the HKS, same piping and tip specs but different steel used. Not sure if it's worth the extra $150 more than the HKS. Bought my HKS at $304, and Kamispeed is now listed at $310. Glad I bought it when I did! Going to use that $6 for some take out!
HKS Cool style: http://www.kamispeed.com/HKS-Cool-St...2024-ah002.htm
Not much louder than stock and I'd imagine pretty heavy since it almost looks exactly like the stock exhaust with the piping for the center exit...
yovtecjustkickedin
19
Sep 28, 2016 10:49 PM
yuffers
Jun 24, 2015 08:55 PM
Enegizer
Jan 17, 2011 02:25 PM
ThEvil0nE
Jul 19, 2010 04:12 PM
saiko
Feb 26, 2008 11:00 PM
