Constant Battery failure on Honda Fits
Old Sep 3, 2024 | 02:54 PM
  #81
Mlrou's Avatar
Update on battery issues
Originally Posted by Mlrou
My 2017 had reoccurring dead battery issues where you would push the start button and nothing would happen but if you jump started it it would fire right up. Finally found out in the middle of the night the electrical system was somehow turning on and draining the battery. Turned out it was a faulty sensor (one that has something to do with alerting you about the hood being closed or tampered with) disconnected that and haven’t had any problems.
It seems the faulty sensor was not the issue as I am having dead battery issues again.
Went to start car. Completely dead. No lights, sound, clicks, nothing.
Jump the battery, it starts up immediately no hesitation. Go for a good long ride and have no problems for about a week. Battery dies again, push the start button absolutely nothing. I’m sitting in the car fiddling with the fob because I’m trying to open it, thinking I’ll try to change the battery, to see if that makes any difference the dashboard suddenly comes on and the car starts.
So I think maybe there is a short/problem with the fob. I get a new one and it seems to work fine for a couple weeks but now it has died again.
So from reading all these posts there seems to be some mysterious problem effecting all these Fits and no one is able to come up with any definitive solutions.
Old Nov 5, 2024 | 04:20 PM
  #82
Reddogs's Avatar
[QUOTE=wasserball;1457954]
Originally Posted by Reddogs
I would agree and went over that with the Honda dealer on both of the Honda Fits and they couldnt find nothing so going for a full test on both on Monday. Now my family has had Honda since forever, Accords, Civics, Passports, etc and they have sat around or been used daily and the battery holds, so I cant figure it out except this battery is smaller and less CCA amperage which I suspect is the cause.[/QUOTE
You need to find what is causing the power consumption. Replacing it with a "bigger" battery is not the answer. OK, for most Americans, yes, bigger is always better.
It has to be a circuit/component that wears down, as I never had any issues the first 50,000 miles. And now I can measure it daily as it goes down.
Old Nov 5, 2024 | 04:21 PM
  #83
Reddogs's Avatar
My 2017 Fit has had the issue of the battery being drained for no apparent reason for over a year. The battery has been checked and is good but something will intermittently drain it dead. It will take a charge immediately and will last for weeks and then happen again.
One night I witnessed the car spontaneously start up the accessories (radio, lights, dashboard)but not actually start. No one was in the driver seat but I was in the car with the fob.
The did extensive testing and traced it to a sensor that lets you know the hood is ajar so we removed the sensor thinking that would fix the issue but 2months later it’s back to finding the battery dead when you try too start it.
My question is has anyone had this issue and solved the problem?
Same issue, I am working on it, but the dealers are no help.
Old Nov 7, 2024 | 06:42 PM
  #84
Chitown Fit's Avatar
Possessed.
Your Fit is possessed.
Old Nov 13, 2024 | 04:57 PM
  #85
bobtull's Avatar
Apparently so is mine
Bought a used 2015 FIT EX for my daughter. For a week everything seemed fine. Then the battery started dying overnight. My mechanic replaced the Alternator. Didn't fix it. Went down the Rabbit Hole of Parasitic Drain and watched numerous videos and forums (for Hondas, Toyotas, BMW's etc.) and checked it. It was drawing around 800 milliamps when all shut down. Looked like fuses 21 and 29 (BACKUP and BACKUP MAIN). My mechanic looked at disconnecting the Radio and the Console based on wiring diagram. It reduced the drain by SOME but not all the way and was still unacceptably high.. I suspect the door locks/keyless entry system as the Driver Side Master Door lock switch is jammed. (But it all works just fine with the FOB....I posted on this earlier). I ordered a replacement but it isn't here yet. My mechanic said he would try disconnecting that switch and see if it improved things. Wondering if anyone has had and solved similar issues. I also tried removing the AC Clutch Relay (something I found in my searches) but that didn't seem to help. Would really like to figure it out vs. replacing lots of things and still not fixing it.
EDIT: UPDATE in case it helps anyone else. Problem was the Immobilizer system not going to sleep. Software update fixed it. No more parasitic drain! Hoping there isn't something else going on that is causing the Immobilizer software to glitch. Just got it back, but it started 2 days in a row after sitting overnight, so hoping it is FIXED. Also replaced the door lock switch with a cheap used part from Ebay. Not the problem, but now I have a working master door lock switch!!
Old Nov 14, 2024 | 04:12 AM
  #86
Mlrou's Avatar
Gave up looking
Finally bought a portable charger to keep in the car. Seems to start reliably with a jump so I’m not putting anymore money into trying to find an answer to this mysterious problem that seemingly has no rhyme or reason whatsoever. So aggravating because I love the car.
Old Nov 14, 2024 | 04:22 AM
  #87
Portable Battery Charger.
This is only a temporary solution.
Using a portal auto battery charger as a way to start your car on an ongoing basis is not a viable long term solution.
Go to a competent Honda Dealer to fix this issue.
Old Nov 14, 2024 | 07:11 AM
  #88
Mlrou's Avatar
Use of portable charger
I only need to use it once every month or two and it seems like several people have this identical problem and have spent a lot of money at dealerships trying to resolve the issue to no avail.
Old Nov 15, 2024 | 02:38 AM
  #89
Honda Dealer Fix.
If you're not far from the Chicago area,
Go to Napleton Honda in Morton Grove Illinois just outside of Chicago.
Outstanding Honda maintenance and repair dealer.
Old Dec 2, 2024 | 06:54 AM
  #90
Reddogs's Avatar
That may be the culprit, as its what I suspected as both the 2015 and 2016 didnt do this at first, but started around the same time as we take them to the dealer for all service pretty much together.
Old Dec 2, 2024 | 06:57 AM
  #91
Reddogs's Avatar
Tell me about it, I have extra batteries in the trunk and trickle as well as regular chargers for both cars trying to keep them going...
Old Dec 2, 2024 | 06:58 AM
  #92
Reddogs's Avatar
Tell me about it, and its $200 plus each time to check for parasitic drain...........
Old Dec 2, 2024 | 07:46 AM
  #93
bobtull's Avatar
So far so good
Good luck!! Just reporting back that since the Immobilizer software update, NO MORE DRAIN. Car starts fine every morning, even now that WINTER has arrived in New Jersey!!
Old Dec 16, 2024 | 09:50 AM
  #94
Reddogs's Avatar
No, mine went down to 12.1 volts just over the weekend while I was away, so nothing I did.
Old Dec 16, 2024 | 09:52 AM
  #95
Reddogs's Avatar
No way, now will have see if the dealers can give me a appointment before next year. And I mean that....!
Old Dec 29, 2024 | 04:00 PM
  #96
2016Fittt's Avatar
EDIT: UPDATE in case it helps anyone else. Problem was the Immobilizer system not going to sleep. Software update fixed it. No more parasitic drain! Hoping there isn't something else going on that is causing the Immobilizer software to glitch. Just got it back, but it started 2 days in a row after sitting overnight, so hoping it is FIXED. Also replaced the door lock switch with a cheap used part from Ebay. Not the problem, but now I have a working master door lock switch!![/QUOTE]
Hi, can you PLEASE tell me how to update the IMMOBILIZER system's software?
thank you!!!
Old Dec 29, 2024 | 09:52 PM
  #97
bobtull's Avatar
The tech at the repair shop did it. I don't really know how he did it but I am assuming he had some diagnostic/update device like the Honda i-HDS:
https://store.honda.com/hondaacura-i-hds-and-vsp
https://honda.oemdtc.com/342/i-hds-d...mming-software
Note, that it may not necessarily be this in your case. In my long journey to get this fixed, it was apparent that there are a TON of modules that can potentially cause this by staying alive and keeping the computer active and drawing current.
Diagnosis is the tough part, but I guess he had the right tool/software to pinpoint it.
Old Dec 30, 2024 | 09:13 AM
  #98
woof's Avatar
I recently took my 2018 Fit in for a software update to fix rear camera problems (an official recall from Honda) and when I was picking my car up I asked if they did a system wide software update as part of the process. The service person said, not as such, but they do check for other modules which have older software and do update them as part of their process. This was my second trip in for this camera software update, the software fix a year earlier apparently didn't work so we had a do over with a new recall.
Old Dec 31, 2024 | 05:34 PM
  #99
dwtaylorpdx's Avatar
When I had a GD1, I was having the dead battery issue, had the alternator tested at the auto parts stores, always tested good.
Fianlly took teh alternator to a shop that does custom rebuilding of alternators and he hooked it to his tester and the ALT was never getting over 13V.
He replaced teh rectifier and 14.7 , he said the diodes in some japanese corp based cars can partially fail and then dont pass correct voltage form all three phases in teh alternator..
He must have been right it lasted for 4 years till it got totaled. And the new rectifier was < 30 bucks.
Old Jan 1, 2025 | 08:47 AM
  #100
bobtull's Avatar
Lucky for the quick diagnostic! For me, when I was trouble shooting it, my first thought was the alternator as well. Using my own multi-meter it looked like it was putting out 14.5 volts or so and I also took it to the Auto parts store and Alternator and Battery tested OK. When I took it to my mechanic, he said the Alternator was bad (not charging) and the belt was also old and should be replaced. I didn't really think that was the case since when it RAN the battery stayed charged for me, but I figured, maybe it was on its last legs, or maybe, as you said there was a bad diode/rectifier with intermittent failures. ~$500 later, the car wouldn't start the next morning and I was back to square one with Parasitic draw diagnostics until the strange Immobilizer issue came to light.
