Intake suggestions.
Old Mar 27, 2021 | 09:40 PM
Peyton Chandler's Avatar
Intake suggestions.
Just as it sounds looking for intake suggestions. If you have done one. Pros/Cons, price range, eased of instal etc.
Old Mar 28, 2021 | 12:47 AM
elkaku's Avatar
I went with the K&N drop in for the oem airbox (which i modded a bit), since the design doesn't helps a lot with the heat... And it has worked pretty nicely with the addition of the TB spacer I custom fabbed with a friend of mine...
We are in the final stage of these ones for blocking off the EGR and eliminating the restrictive sharkfin like thing protruding into 50% of the intake air pass on the IM...
*NOTE: am EGR low flow code will come up (but car will run fine,) but it can be disabled using. KTuner or flashpro*
EGR pasaage on engine
IM plate
Not my pic... Its from a fellow FITter(cant remember who) used it for reference on the shark fin thing blocking almost half of space...
Old Mar 29, 2021 | 09:17 AM
Lhoswald's Avatar
The only one I've seen that looks like a proper design is the takeda aFe 5r cold air intake. Still uses the stock ram air piping from the front but opens up a bit more than stock and uses a conical style filter
Jmconiglio
Aug 21, 2021 12:29 AM
fitisno
May 4, 2011 03:20 PM
iLUVYOURGE8
Jun 20, 2009 01:47 PM
WhEreZmYFiT
Dec 5, 2007 12:46 AM
samwell
Jun 18, 2007 11:13 PM
