MODS/ACCESSORIES for the GK
Old 05-10-2017, 07:27 PM
skatana's Avatar
Thought I had a short on my original adapters I made for my led blinkers. So, I went to the local junker and pulled some blinker connectors from an '05 Civic. Took them apart, then soldered wiring onto the pins to connect the load resistors for the switchbacks. Turns out it's the bulb that's going out, but at least the wiring is a lot prettier now.
  #1542
Old 05-12-2017, 12:28 PM
Thestig0711's Avatar
Finally caved and bought a Yakima Rook rack for the Fit with Jetstream Black bars and the windscreen. Was tired of driving my truck all over toting the yak. Works just great. Get roughly 34mpg on the highway with the yak on top.
  #1543
Old 05-12-2017, 05:36 PM
tsand19151's Avatar
New Auto Dim mirror
Installed new Gentex auto dimming mirror. Install was quite easy.
Amazon Amazon
Attached Thumbnails MODS/ACCESSORIES  for the GK-sunp0009.jpg   MODS/ACCESSORIES  for the GK-sunp0024.jpg
  #1544
Old 05-17-2017, 10:21 AM
iggy's Avatar
New Bra
I just installed the Honda Fit Bra.
Attached Thumbnails MODS/ACCESSORIES  for the GK-honda-bra-002.jpg   MODS/ACCESSORIES  for the GK-honda-bra-001.jpg
  #1545
Old 05-17-2017, 10:22 AM
iggy's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Did you find extra power up there or did you tap in the light circuit?
  #1546
Old 05-17-2017, 10:27 AM
tsand19151's Avatar
I could have easily tapped into the moonroof but I choose to run a wire down to the fuse box. There are two screws that hold the light/moonroof module. One of those can be used for ground.
  #1547
Old 05-17-2017, 10:59 AM
Estri's Avatar
Bought OEM rubber mattings and splashguards
  #1548
Old 05-22-2017, 02:34 AM
HF Integrale's Avatar
How much were the splash guards, if you don't mind me asking?
Part number? Link?
Thanks
  #1549
Old 05-22-2017, 02:37 AM
Plasti-Dipped the OEM wheels and the rear reflectors (and the emblem)
  #1550
Old 05-22-2017, 03:14 AM
Estri's Avatar
Part number? Link?
Thanks
Splash guards
Part number 08P00-T5A-600
68 € for the set (front and rear)
Not sure if they sell it online.
I just went to the dealership to order it.
Catalogue des accessoires
  #1551
Old 05-22-2017, 12:18 PM
Thank you, Estri!
  #1552
Old 06-06-2017, 04:43 PM
O.N.'s Avatar
Would you not get dirt and moisture trapped under resulting in paint damage?
  #1553
Old 06-06-2017, 09:55 PM
tbFit's Avatar
A neighbor pulled their full front hood bra off their prius after a wet winter, the entire hood is solid rust. So much for protecting it. Or one can say, those rock chips are no longer an issue.
  #1554
Old 06-07-2017, 11:04 AM
The clear 3M bra works best. I installed that on my GK. I do have the OEM bra too for long road trips where rocks can be a problem. The idea behind a bra is that you do have to periodically remove it (thats what she said ) so the surface can dry/breath. Its also imperative to clean it so sand/dirt doesn't act like an abrasive and ruin the paint and clearcoat finish.
  #1555
Old 06-13-2017, 04:19 PM
first honda's Avatar
Plastidipped rear hatch garnish and made my own red emblem. I hope the dip holds up.
  #1556
Old 06-13-2017, 07:18 PM
TougeMonster_GK5's Avatar
Spoon Sports Durocon Shift Knob
  #1557
Old 06-17-2017, 04:56 PM
wmb's Avatar
wmb
wmb is offline
Thumbs up I would like to do the same
Originally Posted by Bassguitarist1985
Forgive the sidebar frustration of why the USM Fit EX did not come with these mods like the EX-L did. Had the EX-L been offered in a manual tranny I would have thrown down. Instead I'm modding my EX 6MT to be just as functional and cool as an EX-L, maybe even better!!
2015 Honda Fit EX 6MT Heated Seat Pad Installation Part 01 - YouTube
2015 Honda Fit EX-L LED Winkers Installed on an EX 6MT Part 01 - YouTube
Hi! thatīs a great modification. I have a 2015 Fit, but I live in Mexico and it is very difficult to get those parts. Even the most equiped version(Fit Hit, similar to EX) doestn come with Winkers.
Do you know where I can buy the cover and the winker light?
I would like to set my Fit as cool as yours, but one step at time
  #1558
Old 06-17-2017, 05:46 PM
Not sure for mexico but plenty on here who can advise!
  #1559
Old 06-18-2017, 02:48 PM
orataro's Avatar
I have plans to install Winkers on my LX model. In my case the LX model does not have a wire harness for Winkers so I plan to run my own wire.
I bought the skulls on eBay for around $70.00 for a set. Mind you, they were not the color I needed but my skulls were going to be custom made in Carbon Fiber so color didn't matter.
I bought the Winkers from here,
https://www.aliexpress.com/item/Rear...7-b3bfe0220330
The dealer wanted $80.00 each and they wouldn't sell them to me due to my Fit is a LX model.
Please note, the JDM skulls you might see on eBay will not fit our Fit. They are much smaller in size.
My time was limited so I didn't have the time to install the Winkers but here are my custom Skulls in Carbon Fiber. I had them made for me from Thailand. The Red matches my Red RS grill moulding and Badge.
eBay Mirror cover.
eBay Skull cover. This part varies in price. Often the right side cover sells for well over a $100.00.
http://www.ebay.com/itm/HONDA-OEM-20...NY6~wS&vxp=mtr
Good Luck.
  #1560
Old 06-19-2017, 12:24 PM
wmb's Avatar
wmb
wmb is offline
Thank you guys! Now that I know how to look for, I found this pair of skull covers:
https://www.aliexpress.com/item/2PCS...08.4.81.6tsVbF
However, I am not sure if a they will fit since apparently it work for honda city too, and here in Mexico honda City and Honda Fit are 2 different models.
Anyway, I will buy then together with the turn signal lights (https://www.aliexpress.com/store/pro...05071-VnYZvQVf) and I'll let you know if worked.
Thanks again for your help.
Quick Reply: MODS/ACCESSORIES for the GK
