Does the 2015 Fit use a timing belt or timing chain?
Old Jun 25, 2014 | 05:07 PM
SheepNutz's Avatar
Just asking for research.
Old Jun 25, 2014 | 05:46 PM
mikeygnyc's Avatar
AFAIK a timing chain. Heard that Honda has moved off using belts. Also, the owner's manual (online anyway) doesn't reference anything about a belt.
Old Jun 25, 2014 | 05:53 PM
amy_wilhelmina's Avatar
What is the maintenance like on a timing chain vs. a belt? The timing belt on my SUV has been an expensive PITA over the years...
Old Jun 25, 2014 | 05:56 PM
mikeygnyc's Avatar
In theory it's a zero maintenance item. Should last as long as the engine. In theory anyway... You also should have adequate warning if it needed replacement.
Old Jun 25, 2014 | 06:15 PM
Yay!! One less belt I have to keep replacing!
Old Aug 12, 2014 | 11:30 PM
15BlkPrl's Avatar
All 4 cyl Hondas use a timing chain. V6 models have a belt.
There is no maint intervals for the chain. While durable they can still stretch or guide/tensioner can wear out necessitating replacement. Generally that happens at over 200,000 miles if ever.
A timing belt is a 7 year or 105,000 mile replacement interval. Don't replace it and your are basically playing the lottery but if you "hit the lottery" in this case you lose. Engine damage may result.
Old Aug 13, 2014 | 12:36 AM
randomAustinGuy's Avatar
Timing chains are awesome. The next best thing to a gear-driven cam for reliability. My truck's maintenance guide has the following to say about the timing chain: "Inspect every 100,000 miles." Nice! The worst (nameless) car I ever owned from this perspective required changing the timing belt and water pump every 30,000 miles. *cough* German *cough*
Old Aug 13, 2014 | 01:33 PM
bargainguy's Avatar
Originally Posted by randomAustinGuy
.. The worst (nameless) car I ever owned from this perspective required changing the timing belt and water pump every 30,000 miles. *cough* German *cough*
Wow, and I bet it wasn't cheap on your German laryngitis car, either. Four figures for both belt & pump, mayhaps?
Old Aug 13, 2014 | 11:19 PM
SheepNutz's Avatar
I'm guessing you mean current model cars? I think all of my older 4 cyl Hondas (87 through 95) had timing belts.
Old Aug 13, 2014 | 11:45 PM
15BlkPrl's Avatar
Sorry sheep nuts I wasn't clear. Don't see to many of the timing belt 4 cyl cars come in anymore due to them being so old... Yes all new Hondas 4 cyl now use chains.. Honda used timing belts until about 2000. They phased them out as the new 4cyl models were introduced after that...
Old Aug 14, 2014 | 11:35 AM
Pretty much, $800-$900 in 1995 dollars. All of these types of experiences are why I'm giving up and going back to economy cars. Just not worth the hassle or expense to me any more. I can't wait to start driving my Fit and feeling all smug about the money I'm not spending. I'm glad to see Honda is moving to timing chains. Maybe a bit noisier but so much less service.
Old Aug 17, 2014 | 04:45 AM
Ein's Avatar
Ein
My 04 civic still had a timing belt.
Old Aug 19, 2014 | 09:33 PM
gaeseal's Avatar
So is 10K too much to pay for a 2009 Honda Fit with 89K miles and a clean Carfax report?
2009 Honda Fit Sport, $11,992 - Cars.com
Old Aug 20, 2014 | 09:26 AM
PaleMelanesian's Avatar
That makes sense. The 01-05 Civics still had a D-series engine. It was the 2006 model where Honda went to the 1.8 R-series engine. It wouldn't make sense for them to do a major change like this within the same engine series.
Old Aug 20, 2014 | 09:52 AM
fitisno's Avatar
I spent a bunch of years as a honda/acura tech and most of the chains on the 2.4 engines were stretched and ready for replacement around 150k give or take. Maybe the L is different than the K, hopefully the smaller engine puts less stress on the chain and it lasts longer
Klasse Act
Jul 24, 2021 02:21 AM
jmains89
Jul 23, 2021 10:59 PM
Tonyride
Jun 21, 2018 09:24 AM
Bad/Andy/gk
Apr 17, 2015 11:46 AM
rascuzi
Jul 21, 2006 12:01 PM
