Headrests in front are flippable
Old Jul 30, 2014 | 10:07 PM
TofuShop's Avatar
Hi all,
Not sure about anyone else here, but i like to sit at an almost upright 90 degree angle when driving. I didn't like how the headrests point forward, touching your head and making you look downward. Felt very awkward and uncomfortable to me. So, i tried flipping them, and it works. I can sit upright and not have the headrest touch my head at all now. But it is still there in case of an accident.
Just thought i'd share.
Old Jul 31, 2014 | 08:34 AM
tmfit's Avatar
Yeah I discovered that right after purchase but find if I turn it to the rear I have to tilt my head to far back to make it useful for my purposes but it is a cool feature that can suit either or!
Old Jul 31, 2014 | 08:52 AM
quikser's Avatar
I think that's true for most cars that have adjustable headrests... in my 01 Civic I did it by accident after using it in "long mode".
In my moms Subaru outback, you have to pay attention to distinguish the front seat headrest vs the rear seat headrests... Pulled them all out for moving duty...
I think it's the current style Mustang where you can adjust the fore/aft position of the headrest, wish more cars had that. I'm the opposite of the OP, I prefer the headrest to be RIGHT behind my head in case I get hit from behind.
Old Jul 31, 2014 | 02:22 PM
exl500's Avatar
Do you take them totally out, turn them around, and put them back in? Or just flip the top piece while attached?
It's too hot at the moment to go downstairs and try it myself.
Old Jul 31, 2014 | 04:30 PM
TofuShop's Avatar
Recline the chair, pull the entire headrest out, flip it around, and put it back in
Old Jul 31, 2014 | 10:42 PM
exl500's Avatar
Thanks! I'll try it tomorrow.
Old Aug 1, 2014 | 12:46 PM
sooznd's Avatar
do you need to recline the seat to do this?- isn't there a little plastic button that you can push to remove the headrest? that's how I remove mine on my 2010 fit.
Old Aug 1, 2014 | 01:10 PM
Soupy's Avatar
headrest
There's not enough room between the top of the headrest and the roof to get it out unless you recline the seat. It'll be obvious when you try it.
Old Aug 1, 2014 | 09:47 PM
DrewE's Avatar
When the headrest is flipped around, do the little sawtooth latches hold it, or are they on the wrong side as they are on the GE8? It might not make too much of a difference, I suppose, if there's enough friction to hold the height adjustment in place.
(On the GE8, the headrests backwards are way too far back to be of much use in an accident, and them frontwards are a good bit too far forwards for comfort. I've kind of gotten used to it after a couple of years...but it's still not good, IMHO.)
Old Aug 31, 2014 | 11:57 PM
LSWall's Avatar
Flipping the headrest feels way more comfortable for me - thanks for the tip! But does anyone know whether it provides the same protection in case of an accident?
Old Sep 2, 2014 | 01:39 PM
robot's Avatar
Found this interesting:
New Car Headrests (Head Restraints) Designed Too Far Forward | YogaBack
What is the Proper Headrest Position for your Car Seat? | AdvanceUC.com
Old Sep 12, 2014 | 08:28 PM
CIOWN's Avatar
Hi all,
They are NOT headrests. They are head restraints in case of an accident to prevent injuries from whiplash.
By turning them around you may be defeating their primary purpose in preventing head/neck injuries.
Old Sep 13, 2014 | 02:33 AM
Bon Bon's Avatar
Ha, I thought the dealership put mine in backwards... so I turned them around.
Can't stand trying to drive with my head forced to tilt forward.
Really, does anyone find that bearable let alone comfortable?
Old Sep 13, 2014 | 12:16 PM
CIOWN's Avatar
Maybe they did.
You should have a distance of 2.2 inches or less from the back of the your head. With them turned around do you meet this requirement?
If not then you are opening up yourself to a possible whiplash injury in a rear-end collision.
Old Sep 16, 2014 | 01:22 PM
Bon Bon's Avatar
Thatz a yes! Thanks for info.
Old Sep 16, 2014 | 04:33 PM
Fox944's Avatar
Why dont folks just raise the head restraint so it isnt hitting your head while driving (rather them flipping it around rendering it useless)?
Old Sep 16, 2014 | 05:31 PM
DrewE's Avatar
Probably because they're tall enough that raising it doesn't prevent it from forcing the head into an uncomfortable position. If you're tallish (and perhaps also on the slender side) and like the seat back not too much reclined, no headrest height is really good—some are worse than others, but all force a somewhat unnatural position.
SanDan
Oct 19, 2016 01:07 PM
msbxiv
Jul 5, 2012 10:45 AM
tony123
Apr 13, 2012 10:19 AM
whaap
Mar 17, 2010 09:50 AM
jpmccormac
Apr 8, 2006 12:55 PM
