Radio - Help!
Old Aug 24, 2014 | 03:45 PM
SilverEX15's Avatar
Radio - Help!
I've read the owner's manual, and I've read the Tech Guide, but I'm still having trouble using the radio on my EX.
I can set preset stations, but how can I display them? I can get a list of all available stations, but that's a huge list, with the presets scattered among them.
So, starting with the Audio button, can someone take me through the steps to display my presets?
This is an example of where mechanical - those preset buttons - beats electronic.
Old Aug 24, 2014 | 03:58 PM
exl500's Avatar
Sorry, I haven't managed preset yet despite my efforts.
Old Aug 24, 2014 | 04:06 PM
SilverEX15's Avatar
Well, stay tuned. Someone might know how to do it.
Old Aug 24, 2014 | 04:30 PM
SilverEX15's Avatar
Okay, I think I figured it out, although it's going to be hard to explain.
Get to Audio, then Station List. Press a preset station. When you get that station, press it again. That's how I got the list of presets-only. It wasn't easy reproducing that though. It seems to behave differently at different times. Sometimes when I pressed the preset again, the screen would change, and I would have only that one station displayed. Hitting it again would get me the list of presets.
Keep at it, and you should get it. Pressing the preset station and then pressing it again is the key.
Old Aug 24, 2014 | 04:34 PM
JupiterJoe's Avatar
Here you go SilverEX - Hope this helps.... From the Main Menu press the Audio button. If you need to switch your Source select Source and then Select FM. Once on the FM screen you can view your Preset Stations by pressing on the small little icon in the lower right hand screen that looks like a TAB or Folder Icon. This will then raise the display to show you your preset stations. Also note, that once you are using your Preset stations you can use the LEFT and Right Arrow on the left control pad on the steering wheel to rotate through your Preset Stations... Hope that helps and does the trick... If not, let me know and I will try to take snapshots with some highlights for you ....
Old Aug 24, 2014 | 05:08 PM
SilverEX15's Avatar
Thanks. I'll try that tomorrow.
Silver Surfer
May 24, 2015 01:24 PM
jtraver
Feb 18, 2015 09:11 PM
essaince
Sep 12, 2014 08:32 PM
haudoodles
Aug 20, 2014 08:01 PM
FIT410S
May 15, 2010 12:58 AM
