2015 Honda Fit EX-L - Any idea what are the 16" wheel specs?
Old Aug 28, 2014 | 05:05 PM
Wing0949's Avatar
Hey, I'm new here and I apologize if my initial research in this forum did not yield the results I was looking for.
So, let me pose the question now, if it hasn't been asked or posted: 2015 Honda Fit EX-L - Any idea what are the OEM 16" wheel specs that come with the EX-L are?
Obviously, they are 16" diameter, how about the width? 16x?
Does anyone also know the offset? ET??
Lastly, is it safe to assume the lug size is 4x100?
Anythings to consider if looking for an aftermarket wheel? Does having TPM make a difference?
Thanks in advance.
Old Aug 28, 2014 | 05:12 PM
kaymack's Avatar
On the EX, the 16" tires are 185/55, H rated...I assume they are the same on the EX-L. Mine have Bridgestone Turanzas but I read recently where they are switching to Firestone mid production...but no explanation as to why.
Old Aug 28, 2014 | 05:24 PM
Wing0949's Avatar
Thanks for the info, but I'm actually interested in the wheels themselves, not the tires.
Old Aug 28, 2014 | 05:44 PM
sixth's Avatar
You may want to read this for aftermarket wheels
The OFFICIAL Fit Shoes Thead! (Lug Nuts Included!)
bolt pattern for the oem ex an ex-l wheels are 4-100 ,16" obviously
Old Aug 28, 2014 | 05:52 PM
15BlkPrl's Avatar
4x100 16in by 6.5 +45 offset
Old Aug 28, 2014 | 06:02 PM
Wing0949's Avatar
Cool! Exactly the info I was looking for.. will help when looking for aftermarket wheels and how they may fill up the fender wells, especially knowing the OEM wheels width as well as Offset when comparing to something aftermarket.
Thanks!
Old Aug 28, 2014 | 06:56 PM
Bigbadvoodooguru's Avatar
hub bore is 56.1
a 25mm spacer in the rear brings out the stock tires enough to look similar to the front.
I would say 20mm spacer would be the same look as a stock front, offset wise. 25 is out a teeny bit further.
That would mean if the stock wheel is 6.5in with +45 offset, then keeping width at 6.5", a +25 offset wheel would fit perfectly (as in, the same as the front). These are NOT hella flush measurements btw.
And of course if you change the wheel width, then take the (new wheel width) - 6.5", divide by two, convert to mm, and add that number to the +25 to get the exact same fitment as the stock wheel with a 20mm spacer (flushness wise at least).
Old Sep 12, 2014 | 10:42 PM
CIOWN's Avatar
Oh good god NO. Not Firestone.
I had Firestones on my 98 Ranger that were not part of the recall (because they caused crashes) but were the worst tires I ever had on the truck.
Bridgestone/Firestone announces massive tire recall
Bridgestone/Firestone announces massive tire recall — History.com This Day in History — 8/9/2000
Old Sep 13, 2014 | 09:27 AM
stembridge's Avatar
I took delivery of my Fit a few days ago, and pulled a wheel yesterday to confirm the size is 16x6 (not 6.5 as I had read elsewhere and repeated here in another post). Offset is +53mm, hub bore is 56.1mm as mentioned above. Bolt pattern is 4-100.
My car has the Bridgestones (185/55R16) - my car's build sequence is in the 19000 range.
I just ordered a set of 16x7 +40 wheels and 205/45R16 tires for my car and will post pics when they are installed. I will probably add a 10-15mm spacer to the rears depending on how they look.
Here's a link to an interactive tool you can use to compare different wheel/tire setups: Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
es
(edited to correct offset to +53, not +45)
Old Sep 26, 2014 | 07:10 PM
stembridge's Avatar
Quick pic of my EX with 16x7 +40 wheels and 205/50R16 tires installed:
es
(cross-posted in several tire/wheel threads)
Old Apr 15, 2017 | 05:30 PM
Soon2015FitWillBeMine's Avatar
Anyone know the weight of the stock 2015 FIT EX rim? I looked everywhere including going to one of my local dealers and no one knows. Manufacturer of the rim would help too. Thanks.
Old Aug 2, 2019 | 05:26 PM
Courtney Veinotte's Avatar
es
do you you have any rubbing? How’s handling ?
ej8tofit
Jul 15, 2016 07:31 PM
1969l78nova
May 12, 2015 10:17 PM
rubberman15
Aug 22, 2014 05:28 AM
JediPat
Aug 5, 2014 07:30 PM
