Ambient Fuel Usage Indicator (blue/green lighting) around speedometer
Old Nov 14, 2014 | 11:30 AM
JN2k108's Avatar
Originally Posted by m_x
I mean, not really accurate, but not totally inaccurate I guess. Depends how you're driving.
I have the M/T and those lights just have to be ignored. They seem to ALWAYS be blue unless you're in 6th gear. Shift to a higher gear, lights turn green, then quickly turn to mid blue, then turn dark blue, no matter what the RPM is or how open the throttle is.
For example, say you are going at a steady 25mph in 4th, which is like 1.5k RPM. I find that 2k is sort of the lowest RPM can be before the engine sounds like it's working too hard, so I'm usually in 3rd at 25mph (I know that's just my driving style and others will disagree). So you're going slow at a low RPM in a good gear and the freaking lights are blue! I do not believe you are in any kind of VTEC range at 2k, and yet the lights are blue.
I find the only time they are steady green is when I'm cruising in 6th.
I am very curious to know if I am interpreting this incorrectly.
Well with my driving style, I'm always WOT and according to Wikipedia, these new ivtec will switch to vtec at wot regardless of rpm. I also have the manual and I can feel the car pull harder when it hits 5k which from the dyno graphs (from others) is when the car makes peak hp
Therefore for me blue = vtec lol.
I meant my first post was a joke but Internet comedy doesn't translate well
Old Nov 14, 2014 | 12:55 PM
m_x's Avatar
m_x
Internet comedy getting lost in translation is the story of my life lol. And yeah, all the stuff you said is right; WOT is the only way to drive. 2nd and 3rd gear @ 5k-6.5k is a lot of fun.
Old Nov 14, 2014 | 01:35 PM
JN2k108's Avatar
Oh yesss. Have you tried clutch less shifting yet? It's pretty fun in this car. I also wish we had more revs. Like omg, at wot I'm just shifting constantly. All I hear is the rev limiter
Old Nov 14, 2014 | 02:22 PM
m_x's Avatar
m_x
It's my first manual and I haven't had the balls to try it; it seems like a bold move and I KNOW I would be the one to break stuff trying to do it. It is definitely a fun car though.
At about what RPM do you hit the rev limiter? I have hit the red line, but I didn't push it far enough past to hit the limiter. Somebody on some post in some thread said it's ~300rpm past the red line. Thoughts?
Old Nov 14, 2014 | 11:24 PM
JN2k108's Avatar
i hit the rev limiter at 6500. it wont go any higher for me in 1st, 2nd, 3rd and i haven't found room to hit the rev limiter in 4th yet. lol.
Old Nov 18, 2014 | 06:35 PM
GotFitB13's Avatar
I think I will still be watching my Scangauge when I get my Fit. There's something about watching the instantaneous reading and comparing it to the average.
Old Nov 26, 2014 | 07:44 PM
redhausman's Avatar
I don't understand why the ambient meter doesn't match the mpg gauge. Are they supposed to be measuring something different? Like if I'm coasting down a hill pressing the clutch, the mpg gauge shows max (90 mpg), but sometimes the ambient meter shows blue. Makes no sense. Or sometimes as you're slowing down it will cycle from blue to light blue to green and back to blue. Frustrating. In the lower gears, the only times it hits green is if you're in the bottom range recommended for that gear (like 30 mph in 4th gear).
Old Nov 27, 2014 | 10:36 PM
cheesewhiz's Avatar
Are you also experiencing any clutch delay? I have experimented with WOT acceleration but it sounds as if I'm not releasing the throttle when I depress the clutch ... even though I know I released the throttle..... engine still maintaining high rpm. Is this a function of the vtech? Very curious about this as I am enjoying WOT but do not want to damage anything in my new pocket rocket.
Man ... you got THAT right .. every time I try to add some humor I end up pissing someone off! I guess I'm not that funny
Old Nov 28, 2014 | 05:23 PM
simonx314's Avatar
redhausman,
I find that the eco coaching ambient meter correlates heavily with throttle position. If you press down the accelerator pedal further, the gauge turns turquoise then blue, regardless of MPG. I measured this correlation with an OBD reader and the Torque app for Android.
Below 20 MPH
Green = throttle less than 25%
Turquoise = throttle between 25-30%
Blue = >30%
Above 20 MPH
Green = below 20%
Turquoise= 20-25%
Blue = >25%
Old Nov 28, 2014 | 11:04 PM
redhausman's Avatar
simonx314, thanks for your reply. I'm not very "mechanically inclined." Would you say the throttle position that it measures is something worth paying attention to, or should I basically ignore the ambient meter?
Old Nov 28, 2014 | 11:09 PM
DArkk's Avatar
The throttle and relation to the speed. Easiest I can describe it once you've built up enough momentum after acceleration the lights should stay green most of the time until you press harder on the gas pedal.
It's just giving you heads up that the engine is working harder to get the car up to speed until it reaches that point.
You can glance at it once in awhile to see how you are doing.
Old Nov 28, 2014 | 11:33 PM
  #32
GotFitB13's Avatar
This is what the owner's manual says:
Changes color to reflect your driving style.
Green: Fuel efficient driving
Blue green: Moderate acceleration/deceleration
Blue: Aggressive acceleration/deceleration
● The ambient meter color changes in accordance
with your brake or accelerator pedal operation
So if you decelerate too fast it must think you're not coasting efficiently. My Corolla is a 3 speed and as soon as I let of the gas the car is already engine braking to an extent. But if I leave just a little pressure on the gas pedal it coasts pretty good with minimal fuel consumption.
Old Nov 29, 2014 | 05:23 PM
  #33
NotBlake's Avatar
That's because clutch-in coasting isn't fuel efficient. When you push the clutch in, the engine has to restart fuel injection to keep the engine from stalling. It is more efficient to select a high gear and let the clutch engage so that the momentum of your car maintains sufficient engine RPM to provide lubrication and accessory power. When you let off the throttle in gear your car literally uses no fuel at all, zero.
See, the eco guide isn't as dumb as it seems. But I still wish we could turn the damn thing off.
Old Nov 29, 2014 | 09:28 PM
  #34
redhausman's Avatar
Thanks for your reply, NotBlake. I read a few debates online about whether it's better to slow down by braking or by down-shifting. Some of them say brakes are cheaper and easier to replace than clutches. Others say it doesn't cause extra wear on the clutch or other parts to slow somewhat by down-shifting. The ambient meter seems to favor down-shifting over braking, and it consistently goes green when I let it slow in gear instead of "clutch-in coasting."
Old Nov 30, 2014 | 02:32 PM
  #35
simonx314's Avatar
This car gets great mileage no matter what, but if you try to keep the ambient meter from turning blue, you will get even better mileage, but if you'd rather just drive and not pay attention to it then that is fine, because you only save a few cents at the pump by hypermiling. The ambient meter is just encouraging you not to press the pedal down too far.
Old Nov 30, 2014 | 03:01 PM
  #36
trashercan's Avatar
Fuelly Tag Lines ???
Sorry a little off topic but there are a number of people with their Fuelly data being displayed in their tag line seemingly real time - it must have been posted before but I cant find it sorry, could someone show me how to do it ?
Old Nov 30, 2014 | 03:24 PM
  #37
simonx314's Avatar
Go to your vehicle's page on fuelly.com, then scroll down a bit and on the right you will see a white box that says "Share your MPG". Follow the link and on the next page you can copy and paste that code into your forum signature.
Old Nov 30, 2014 | 05:37 PM
  #38
NotBlake's Avatar
I don't mean like constantly downshifting to stop. I just mean that if you're say going 45mph and you know that you need to start to slowing down. you should just stay in gear rather than clutch in immediately. Or if you are decending a hill, better to stay in gear than clutch-in. that's all.
Old Nov 30, 2014 | 09:23 PM
  #39
trashercan's Avatar
Really dumb question, where do I find my signature setting in my profile I haven't set it before and I am damned if I can see where to set it,
Cheers
Old Nov 30, 2014 | 09:42 PM
  #40
Fitmo's Avatar
One the top left of the page, click User CP on the left end of the blue bar. It's in the left column on the subsequent page.
