Front floor well lighting solution ?
Old Nov 23, 2014 | 12:11 PM
trashercan's Avatar
Does anyone have a good product to buy for floor well lighting that obviously comes on with the door being opened and somehow attached to the dome light settings ? I have seen how people have wired in LED door sill protectors into the fusebox with adapted Molex connectors but I dont know what product others have found to deliver the actual light.
Thanks in advance..
Old Nov 23, 2014 | 02:12 PM
mecevans's Avatar
There is a factory floor illumination kit. Biggest improvement will be led dome lights.
Old Nov 23, 2014 | 02:30 PM
DArkk's Avatar
Yep, LED dome lights really makes a huge improvement. I did the same for the cargo light.
Old Nov 23, 2014 | 10:47 PM
JupiterJoe's Avatar
I used these lights on E-Bay --- http://www.ebay.com/itm/4pcs-Blue-3LED-Car-Charge-12V-Glow-Interior-Decorative-Atmosphere-Light-Lamp-/221613642551?pt=Motors_Car_Truck_Parts_Accessories&hash=item339933d337&vxp=mtr
I am guessing you could find something similar in a white light if you are looking for a white light rather than something decorative. As for where to hook them up - See this earlier post on how to tie into the fuse panel under the dash...
https://www.fitfreak.net/forums/3rd-...ht-wiring.html
This turned out to be a pretty inexpensive upgrade for me. I had already done the Fit DoorSill illuminated plates that I got from China on E-Bay so I just tapped into that existing wiring. But I think the Dome light post should give you everything you need. As another reference I used the Honda directions for installing the Door Sill plates and the Illuminated Floor lights as a guide for installation - as it provides guidance on how to remove all the various plastic pieces under the front dash and along the floor boards. (You can find these at several of the online Honda Parts stores if you have trouble locating them)...
Old Nov 24, 2014 | 11:19 AM
trashercan's Avatar
Thanks guys I will have a look...
I have ordered LED bulbs for the interior and will see what difference they make before putting in something like this... Cheers
Originally Posted by JupiterJoe
I used these lights on E-Bay --- 4pcs Blue 3LED Car Charge 12V Glow Interior Decorative Atmosphere Light Lamp | eBay
uzapuca
Aug 9, 2016 04:36 PM
over40pirate
Apr 25, 2013 12:25 PM
baseexcisionrepair
Jan 11, 2012 07:00 PM
thedeadpoet000
Aug 26, 2007 01:09 AM
MINI-Fit
Nov 24, 2006 12:48 PM
