Below MPG ratings.. Need help
If this is your first car, then you probably have no experience with the concept of driving for fuel efficiency, which can be quite different than driving to get from point A to point B. If you are serious about learning how to improve your mpg, listen to what some of the posters are saying here, or better yet check out fuelly.com, cleanmpg.com or ecomodder.com.
Honda does a good job of designing cars properly and not focusing too much on the EPA test. If conditions are good and you do the right things, you can smoke the EPA ratings.
Thats not exactly true. EPA numbers are suppose to be based on some formula. Optimizing driving will result in the EPA cracking down on them and forcing them to hand out gas cards (its happened...recently). Now a manufacturer will certainly make a car with the EPA formula in mind to help with MPG numbers that they will post.
I've heard that the Mitsubishi Mirage can get ~70 mpg depending on your driving habits. But you wont see the manufacturer post that number on the sticker they put on the car on the lots.
I drive a short distance (1/2 mile one way 5 times a week) and I get 22 MPG. When I drive further on occasion, I may get 25/27 MPG. It just depends. That's in the cooler months. It will be different in Summer.
2015 Fit
2013 Civic
Last I read the MPG city test is 11 miles in 30 min, with max speeds of over 50mph (LOL)
Detailed Test Information
I commute in SF in the evening/early morning where traffic is lighter, go 6 miles in 30 min with roughly twice the amount of stops as that graph, and I get 26-28 mpg consistently. If I take the freeway home with no traffic it'll go up to 30-32. If I drove in Manhattan in the daytime in the busy areas I'd expect to get 24 or even lower.
Nothing wrong with your car
FIT-tles Worth
Sep 14, 2011 07:16 PM
ItstheWoo
Aug 12, 2011 02:36 PM
BoostTed
Dec 20, 2010 12:38 AM
phuccer
Jul 23, 2010 10:35 PM
