New Antifreeze, Anyone?
I just use the factory antifreeze on all my cars.
just a tip though, i use this spill proof funnel from Lisle. works great for burping the air out of the system with absolutely no mess or fuss.
Don't be so hard on the guy.
Looking at your MPG I can tell you don't race so changing your brake fluid annually is again a waste of time an money. Biannually is fine and even then, I'd do a visual inspection of the master cylinder and if it looks nice and light apple juice color, I'd leave it. Disposing of these chemicals is also not good for the environment.
ive not had much corrosion build up actually, thus slowed down the interval for the brake fluid change.
I take the car in to the dealer once a year. They have "test strips" which can tell if the brake fluid is "good" or "needs changing". I changed the brake fluid in my '09 at about 5 years, based on the dealer's testing.
yah, honestly that sounds about right, 4-5yrs. unless i change pads earlier since im working on the brakes anyway.
And the cap fits the Fit? A reviewer said that the caps supplied weren't a good fit for his Pontiac.
Yes, the Funnel-Fill kit normally comes with the 3 standard twist type automotive radiator adapters (shown below), and it looks like the kits (link, above) now come with at least one screw type cap adapter for "newer GM", which may or may not fit some cars as there are several different sizes of those from various auto manufacturers.
#32
Googled, found one set almost dirt cheap -----link here:
#33
It's a valuable tool to have around.
#34
I just bought some zerex asian blue from O'Reilly auto parts - product page here.
You can confirm the product's specs at Zerex's site. Says it meets JIS K 2234-1994 spec. This is a Japanese organization's spec. This spec has been "superceded" by JIS K 2234-2006. I don't think Honda publishes any specs.
I'm not changing my coolant now. Just adding a little bit, because it is right at the bottom line, the "minimum" line, of the expansion tank, when cold. Tank is very small, and the bottom line is pretty close to the bottom of the tank. Dealer checked my coolant level as part of their "free multipoint inspection" and decided it was fine; when they looked at it, it was hot and only about 3 mm above the bottom line. They thought that was just fine? I thought the level should be a little higher. I want to add a little more coolant. Maybe 100 ml.
Though I'm using the Xerex coolant now just to add a bit of coolant to the expansion tank, and feel pretty safe doing that, I'd also feel pretty safe using the Zerex coolant when it comes time to drain all the coolant and refill. The Zerex is "hybrid organic acid technology plus phosphate, and no silicates." This is what I understand Honda wants. "No silicates" being the most important. Zerex is labeled "5 year 150,000 mile." Honda says change after about 100,000 miles I think, or a number of years (I'm not sure how many, maybe it's 7) - whichever comes first. I'm guessing that probably the worst case scenario when doing a coolant change would be that the zerex would not protect against corrosion for as long as the genunine honda, and that it might have to be drained and refilled again earlier. But its labeled for 150,000 miles. I find it hard to believe that the honda product is really any better.
Zerex has the same thing with red-pink dye. But I got the blue to match Honda's coolant color. Same price.
#36
Using Honda Long Life Antifreeze/Coolant Type 2 would be my recommendation as well.
#37
I did a little looking around on-line and I found out that Honda type 2 coolant is manufactured by CCI manufacturing il corp. Co does a lot of manufacturing in India. The a coolant product that they sell under their own name in India and other places is called Golden Cruiser. You can find the MSDS or SDS various coolants but I don't think they list all the ingredients. Some are listed as "proprietary;" perhaps others may not be listed because they are not hazardous.
#38
Invest
In my opinion, vehicles are multiple Thousand of Dollar investments. It always surprises me when people want to save a few bucks on things like Oil, Filters, and Fluids.
In nearly all those cases the most expensive vs. bargain brand is minimal. And since we are talking about a high investment machine of which we are hoping for extended life and durability? Never worth saving a few bucks.
#39
#40
Here is some more stuff I found about Honda type 2 coolant. This doesn't prove fitchet's opinion is wrong, but it adds more evidence that perhaps honda's recommendation to use only their product, may be more of a marketing gimmick than a valid recommendation. Not only does CCI manufacture Honda type 2 coolant, but it also manufactures the coolant that Hyundai-Kia, and several Japanese companies, put in their cars. I can't find any evidence that they make a different product for Honda than the product they make for the other Asian companies. That doesn't mean it isn't so. But what I did find is that while the other Asian companies use CCI's product in their cars, they don't insist on their "own brand" being used to add to or replace the original coolant. CCI claims that their coolant is the best coolant in the world, and this may be so. But do they sell their own product at the same price that Honda sells Honda type 2? I am trying to find out if they sell their own "Golden Cruiser" coolant at competitive prices, and if one of the 2 or 3 types of coolant they sell, is exactly the same, or not, as the Honda type 2 coolant.
Hyundai dealers sell a product labeled "Hyundai Golden Cruiser Coolant." I'd bet that this is the same product as one of the 2 or three products that CCI labels as Golden Cruiser coolant for cars. One of their 3 products is "Summer-Smart" coolant. Probably simply has more water and less ethylene glycol. The other 2 products they sell for cars (as opposed to products they have for diesel trucks) - I am not sure if they are different or not, they may simply be a concentrated version and a version pre-mixed with water 50-50.
