USB port not charging
Old Apr 30, 2016 | 01:01 PM
Shipoffools's Avatar
After a week of having my car, the usb port doesn't properly work. I have only used it to charge my moto x, so I haven't overloaded it. When I first plug it in, it indicates that the phone is charging on the lock screen but once I unlock it, the phone doesn't charge anymore. Is anyone else having issues with their phone charging. I have a USB cigarette lighter adapter, but I would rather use the one that came with the car.
Old Apr 30, 2016 | 01:57 PM
csb101's Avatar
make sure your USB cable, USB connector on both ends, the USB end to the Car and the End that connects to your phone isn't damaged or have anything torn, bent. If it okay condition, try and borrow another USB connector and see if that works.
Old Apr 30, 2016 | 02:43 PM
Desmond Lamar MacRae's Avatar
That port isnt for charging. Only works 1 volt. It'll only do trickle charge. The best way to us it most effective, the shorter the cable, the faster the charge will be. My stock Samsung charging cable is just too long to give any effect. Also turn off the data while using that port. Syncing your email and such wille use more energy than that charger can replace. If you want faster charge, get cig lighter charger. it charges like most home chargers.some have 2 USB ports. 1-2amp and 1-1amp fora sec pax phone to do a slow charge. I hope this helps.
Old Apr 30, 2016 | 03:27 PM
2Rismo2's Avatar
I've got a moto x pure and I don't bother with the built in usb ports on the fit. They're only 1 amp and they take forever to charge. Instead I bought an Anker 4 port that can send 2.1 amp to each port. The phone still charges while I stream music and run Waze at the same time
Old Apr 30, 2016 | 03:36 PM
Why would they bother putting a port that can't even charge a phone? I'm gonna have some words with the salesman about it. I have a lighter adapter, but using the USB port looks cleaner and is more convenient. Pretty useless of Honda to put a barely functional port there.
Old Apr 30, 2016 | 04:00 PM
TorontoBoy's Avatar
That USB port can be used to connect your phone to the infotainment system, which should provide higher quality sound than bluetooth. Unfortunately it is low powered so the more you use it the less power you have in your phone.
I'll be adding a secondary 12v power supply, switched with a relay, and then one of those 12v to USB plugin sockets. I'm planning to be able to run my GPS as well as charge the device.
Has anyone plugged into a 12v USB port for more power and then connect with bluetooth? Does this work? It should. That way you'll have a freshly charged phone on arrival.
Old Apr 30, 2016 | 04:31 PM
Uncle Gary's Avatar
The USB port works great for powering thumb drives. I have all my music on a pair of thumb drives in the two USB ports.
I figure that was their intended purpose.
Old Apr 30, 2016 | 09:25 PM
2Rismo2's Avatar
That's how I have it setup, though I was lazy and just used a splitter on the front 12v outlet. It powers my cell phone through an Anker 4 port 12v adapter and my Garmin. Each port on the Anker can apply 2.1 amps individually. It's perfectly OK to use a12v USB adapter to power your phone and connect through Bluetooth.
Old Apr 30, 2016 | 11:22 PM
TorontoBoy's Avatar
Thanks for the confirmation. I'll be adding an extra accessory plug this summer, or when the weather warms up.
Old May 3, 2016 | 12:14 PM
Chazman's Avatar
Wow, something new!
Old May 31, 2016 | 10:35 PM
My main problem is when I first plug my phone in, it says it's charging on the lock screen(Android). Once I unlock the phone, it no longer indicates charging.
My wife recently bought a Fit EX.(I have an LX). I decided to experiment a little and took the cord that I use to her car. The phone charges while unlocked on both USB ports. Are the ports made differently on the EX?
Old Jul 31, 2016 | 04:28 PM
tbFit's Avatar
fyi... I just confirmed that I get a full 1.9 amps with my thick charge cord and only .8 amps with my thin cord. I used the galaxy charge app that works with my S4 and shows the current charge current. The 1.9 amps also matches my high capacity original wall charger.
So bottom line, the USB port under the dash in the '15 EX is capable of at least 1.9 amps with the right cord.
Old Feb 21, 2017 | 02:28 PM
Suezeekay@75's Avatar
Does the
2015 fit lx have a usb port?
Old Feb 21, 2017 | 07:05 PM
orataro's Avatar
I just chose to install this power adaptor. 12v outlets with USB outlets.
Old Feb 21, 2017 | 08:10 PM
huh, dat really sucks.. should be able to charge ur phone WHILE using USB access... something honda definitely needs to work on next time around.
all my cars can charge my iphone6S no issue while fully accessing like maps off carplay, native apps and all.
Old Feb 22, 2017 | 06:21 AM
axlline's Avatar
Really? It charges my i6 just fine, locked or otherwise.
Old Feb 22, 2017 | 01:49 PM
Sounds good, datz da way it should be!!
Old Feb 22, 2017 | 03:16 PM
GeorgeL's Avatar
Yes it does, and I've also found that it also doesn't charge a phone. I think that it is only useful for thumb drives. I ended up using the cigar lighter socket with an adapter which is rather kludgy looking. Thanks Honda.
Old Mar 3, 2017 | 01:15 AM
Does the 2015 Fit LX have a cigarette lighter? If not, where is the usb port located?
Old Mar 3, 2017 | 09:57 AM
TorontoBoy's Avatar
None of the 2015-17 Fits have a cigarette lighter, as smoking has fallen out of favour, but they all come with a 12v outlet. The single USB port is nearby.
