Honda Fit 2016 Gas Pipe removal
Old May 15, 2016 | 03:42 PM
salamlaith's Avatar
hi, this's my first thread, I bought a vandalized Honda fit 2015, last thing that I found that the someone tried to stuff sugar on the gas pipe to damaged the engine (it doesn't), the good thing is that the Honda fit gas pipe is too long with many curves, the sugar accumulated in the middle of the pipe making a blockage.
anyway I had to remove the gas pipe to clean is and put it back, I took some pictures and share it with you, it might help you to do other maintenance.
Attached Thumbnails Honda Fit 2016 Gas Pipe removal-wp_20160508_09_34_35_pro.jpg   Honda Fit 2016 Gas Pipe removal-wp_20160508_09_34_52_pro.jpg   Honda Fit 2016 Gas Pipe removal-wp_20160508_10_06_34_pro.jpg   Honda Fit 2016 Gas Pipe removal-wp_20160508_11_20_23_pro.jpg   Honda Fit 2016 Gas Pipe removal-wp_20160508_10_49_41_pro.jpg
Old May 15, 2016 | 05:11 PM
James Butler's Avatar
Thanks for the great pictures.
James
Old May 16, 2016 | 02:24 PM
Press Fit's Avatar
Nice Fit anatomy lesson. Thanks for the photos.
Old May 16, 2016 | 04:07 PM
GeorgeL's Avatar
Nice pictures! The gearhead in me wants to add an auxiliary tank somewhere along that loooooong fill circuit. The way the long pipe restricts flow means the fuel backs up and shuts off the nozzle when there is still 2 gallons of capacity left! That's 70+ miles!
Old May 16, 2016 | 05:13 PM
dwtaylorpdx's Avatar
FWIW fuel systems need an air gap at the top of the tank for the eval system to work correctly and not get ruined (It typically is bad to fill the charcoal canniest full of fuel...)
Old May 16, 2016 | 05:54 PM
xxryu139xx's Avatar
i like this idea.
OP. curious how much u paid for this vandalized car.
Old May 16, 2016 | 11:25 PM
GeorgeL's Avatar
This is true, but modern tanks have the air space built in above the fill vent and this space cannot be filled with fuel. Otherwise, a slow pump could "overfill" the tank before shutoff. It's pretty idiot-proof
The EVAP canister is on the firewall above the level of the tank. You can't get gasoline into the canister by overfilling. Even if you filled it all the way to the brim and the gasoline then expanded there is still enough vapor space in the tank to keep gas out of the canister.
When I fill, the tank always takes slightly less than 2 gallons after auto-shut-off. I always drive a few miles after filling, so the fill pipe doesn't stay full for long. I typically get 350-370 miles from a tank.
Aliyah Lassiter
Oct 21, 2018 02:57 AM
GQ_Style
May 4, 2018 01:07 PM
salamlaith
May 23, 2016 12:12 AM
finlandhonda
Jun 3, 2015 12:16 PM
sp00n3R
Oct 18, 2007 12:44 AM
