Stopping the Engine - While Driving
Old Oct 23, 2016 | 02:14 PM
SilverEX15's Avatar
Originally Posted by AFittingName
For emergencies.
The power steering is electric, so as long as the battery is connected it should work. Hence why when the key is in "full power" mode the steering still has power. You wouldn't want to unexpectedly lose this should the engine quit during operation.
All power braking systems in all cars pretty much have a "power reservoir" of braking in case of engine shut-off, for emergencies. That's just how the system is made:
https://youtu.be/0sj5d48mcss?t=2m8s
Aren't the brakes electric, too?
Old Oct 25, 2016 | 11:19 PM
DrewE's Avatar
Brake assist is vacuum, I believe; it is on (virtually) all cars, and certainly is on the GE8 Fit. The ABS system is of course electrically powered.
Even without the power assist, there is still braking available; it just requires a lot more pressure on the pedal. This is true for any vehicle with hydraulic brakes. It's worthwhile to get a feel for this in a safe place such as an empty parking lot so you have some idea what to expect should you ever need to stop the car without power assist.
Those trucks and busses and similar vehicles that have air brakes are different. Without air pressure, the service brakes are inoperative and the parking brakes are applied full force automatically.
Old Oct 26, 2016 | 06:31 AM
SilverEX15's Avatar
From what I've seen about air brakes, it the air pressure that releases the brakes. If there is no pressure, the brakes lock up.
Old Oct 26, 2016 | 02:47 PM
DrewE's Avatar
Yes and no. The actual power to apply the brakes (i.e. to push the shoes or pads against the drum or disc) comes from air pressure, stored in an auxiliary reservoir. A clever triple valve controls the application of this air pressure to the brakes: if the supply pressure drops, it allows air to flow from the reservoir to the braking mechanism, and if it increases, it vents the pressure from the braking mechanism (to release the brakes) and also allows air to flow to refill the reservoir. So it's the air pressure that applies the brakes, but it's controlled by a drop in the air pressure in the system, and a sudden and complete loss of air pressure (say from a broken air hose) would indeed apply all the brakes with full force. If, however, the entire system is not pressurized, the service brakes cannot operate at all; pressing the brake pedal has no effect on them, unlike a hydraulic brake system where it still activates the brakes.
On a truck, there is also a parking/emergency brake system that is applied by spring pressure and released by the supply air pressure. This is separate from the service brakes (at least partly separate), rather akin to the hand brake on our Fits.
Old Oct 26, 2016 | 05:28 PM
SilverEX15's Avatar
I watched an interesting series on Netflix, "Highway Thru Hell," about a towing company in NW Canada. They pull big rigs that flip over. Very often, the brake air lines are broken, and it's difficult to release each brake manually by turning a special bolt into each one.
Padawan
Dec 18, 2014 08:13 AM
Namae Kana
Nov 10, 2014 12:56 PM
Goobers
Dec 27, 2011 08:51 PM
boon4376
Aug 10, 2008 09:09 AM
Stan
Oct 15, 2005 10:32 AM
