Air bag light is on for 2 weeks.
Old Oct 23, 2017 | 12:44 PM
ritholtz's Avatar
I started noticing airbag light for last 2 weeks. It is not going away. How do i reset or make it go away. Is there something wrong with my air bags.
Thanks
Old Oct 23, 2017 | 01:06 PM
exl500's Avatar
Which one? The one above the radio stays on.
Old Oct 23, 2017 | 11:14 PM
ritholtz's Avatar
This one is located in odometer. It is just above cruise on light and next to break light. Thanks
Old Oct 23, 2017 | 11:18 PM
exl500's Avatar
I'd see the dealer, especially if it's under warranty.
Old Oct 24, 2017 | 08:04 PM
Brain Champagne's Avatar
So a warning light goes off and your first thought is that the light is broken?
Go get it checked out!
Old Oct 30, 2017 | 11:10 AM
ritholtz's Avatar
Checked with Dealer. They did reset something. They identified some issues like warped front rotors, alignment, tire rotation and cabin air filter for $480. I can do rotation for free. I bought my own cabin air filter to replace. I have to take it back to dealer for fixing warped front rotors and alignment. Brakes and rotors are out of warranty after 12 months.
Not sure why i have front rotors warped in less than 3 years. I bought some tires which are little wider than factory.
Old Oct 31, 2017 | 02:55 AM
hasdrubal's Avatar
Brake discs are rarely actually warped, most of the time it's uneven deposits from the pads. If you're comfortable working on your car, you could try sanding the discs and bedding the pads again, but depending on the mileage it might be time to replace them anyway.
-Warped- Brake Disc and Other Myths
damoaten
Feb 28, 2013 06:40 AM
pennywize182
Dec 11, 2010 01:09 PM
esamson7
Sep 21, 2010 07:46 PM
pwnstar
May 19, 2008 11:27 PM
spreadhead
Jul 11, 2006 08:22 PM
