2015 Fit EX-L - Can it use 195/55R16 Tires?
Old Nov 5, 2017 | 08:33 AM
solenoid's Avatar
My parent have a nice barely used set of Hakkapeliitta tires for a car they sold off, and I am wondering if its possible for them to be used on my fit for the winter and avoid shelling out for new ones.
Can a 2015 fit use 195/55R16 Tires? (don't be too hard on me, I know almost nothing about cars, and less about tires)
Thanks!
Old Nov 5, 2017 | 09:30 AM
sneefy's Avatar
I bet they'd fit just fine if you're on stock wheels and suspension. They're only another 5mm on the radius. Width shouldn't be an issue as people run 205 width tires. Not a dramatic difference.
For reference, input the sizing here: http://www.rimsntires.com/specspro.jsp
OEM 16" wheels are 6" wide and have a +53 offset.
Old Nov 5, 2017 | 09:50 AM
solenoid's Avatar
For reference, input the sizing here: Custom rims, wheel tire packages
Thanks! I will try out that site
Old Nov 5, 2017 | 12:31 PM
Hootie's Avatar
^^ Agreed. You should be fine with running 195/55R16s on your factory wheels... assuming that the car is completely stock or factory otherwise. You may notice that the speedometer with be just a hair off but nothing drastic.
Linked below is a tire size comparison between the factory 185/55R16 and 195/55R16.
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Old Nov 5, 2017 | 12:46 PM
solenoid's Avatar
Yeah, EX-L with I think the default wheels. Will the place I go to get them put on know enough to put them on correctly and not tell me to get a different size you think?
Old Nov 5, 2017 | 02:49 PM
Hootie's Avatar
Some places may or may not try to push the factory 185 size.
These should fit ok though... They're just a smidge wider by 10mm and taller by less than half an inch.
Old Nov 5, 2017 | 03:57 PM
sneefy's Avatar
You won't really know until you ask them to mount the tires. Some shops will push back, some won't.
Hondafitdriver
Oct 3, 2018 03:27 PM
bigbacon
Jul 27, 2015 06:51 PM
ezduzit
Jun 19, 2008 04:30 PM
Pursang
Mar 1, 2008 01:13 PM
squareback
Aug 3, 2007 07:06 PM
