"Cancel" button issue
My 2018 has under 5k miles on, and already I am having issues with the Cancel button on the steering wheel. It has started sticking a bit when trying to press it. And it takes more force than it used to, almost like it's off center or something. Nothing has gotten into it. And while I probably use my cruise a bit more than average, I cannot believe that this is regular wear and tear after less than 5k miles.
Anyone else have this issue? Any ideas on an easy fix (before I throw a temper tantrum at the dealer)? |
If it was me, I'd take it to the dealership ASAP.
The longer you wait, the weaker the case that it is NOT regular wear and tear becomes. At less than 5K miles, I think you have a good case that it should be covered under warranty. No need for a temper tantrum. Just present the problem. |
tap the brake.that should turn it off ?
check for a seed or bit of dirt jammed in the side of the button...like the iphone button problem...lol |
That's what I do. I don't think I've ever used the cancel button. I like the fact that tapping the brake also flashes the brake light to warn any drivers behind that you're slowing down. Gives them a chance to wake up and start paying attention.
I will have to go back to the dealer....my hesitance there is because, when I bought the car, the trim piece around the sun roof button was cracked, and it took them 2 months, and me bugging them 4-5 different times, for them to actually get anything done about it. So I am afraid to even try to get something else fixed.
I know you can tap the brake to turn it off. I drive a 6spd, and I usually prefer coasting and downshifting to slow down, especially when getting off exit ramps. Even though tapping the brake just enough to turn it off won't really effect it at all, it's still a feature that we have that isn't working right on my brand new car And honestly, it worries me that more might come up... :( |
Originally Posted by 2015FITEX
(Post 1395241)
check for a seed or bit of dirt jammed in the side of the button...like the iphone button problem...lol Who'm I kidding. I drive like grandpa. |
Too many suggestions that don't resolve the problem. The best one yet, trade in the car! QuiGonQuinn has a problem, and the solution is take it to the dealer, like it or not. But, OK, WD40 is the world's savior.
If the dealer gives you the run around replacing a part, go to a different dealer. Make sure you rate the bad dealer appropriately on all surveys. Eventually you will get asked how it can be made right.
There is zero reason you should have to live with a broken anything on a new car. |
Originally Posted by wasserball
(Post 1395261)
Sure there are 3 ways to cancel cruise control, brake, hit the cruise button or hit cancel. But that really isn't the point. It's nearly a brand new vehicle, if the button is defective, not working, or just not right,- it should be fixed. Personally? If I was sure it wasn't me that caused the damage, I'd want it looked at while it was still under warranty. The point isn't that there are multiple ways of cancelling cruise control, the point is his cancel button isn't working right. |
I've taken apart these buttons. They are "sprung" by a rubber membrane, with guides/grooves on the sides of the button. Something must have made it's way into there.
(Post 1395261)
Originally Posted by QuiGonQuinn
(Post 1395257)
........it's still a feature that we have that isn't working right on my brand new car
And honestly, it worries me that more might come up... :( A while back I read a local newspaper article about someone who had just had the the dealer install the 4th transmission on his Ford car (Ford Focus or something like that). The car hadn't even made it out of warranty and they had already replaced the dual-clutch transmission three times. I remember thinking to myself "Now there's somebody who has good reason to complain about the quality of the car he bought!". I am reminded of this article every time I read something on this forum where people are complaining about their problems with the Fit. |
I think I'll try some compressed air, in case something got lodged in there. And maybe WD-40 if that doesn't work. Then, if that doesn't fix it, I'll bring it to the dealer. I'm just frustrated by having to deal with them, but I guess that's the game they play, making it difficult for me to do warranty stuff so I won't want to...ugh...
Not sure about wd-40, but I'd try liquid graphite. Only AFTER I had the dealership work on it though. You don't want to do before, because they can blame your "fix" for the cause and deny warranty repair.
And if you fix it with the lubricant the dealership won't touch it because they'll say "Look, no problem. It's working OK. Get lost. ". Lubricant is really only a temporary fix if it works because sooner or later it'd dry out and you'd have to apply it again.
Originally Posted by 2Rismo2
(Post 1395409)
Broken through no fault of your own? That should be covered under warranty. Broken? And you've squirted WD-40 or graphite in there? You can be blamed. Or at least it looks a lot more suspicious when you drive in looking for warranty coverage. I'd give them 1 clean shot at fixing it. It is under warranty after all. |
