How to remove temp control panel?
Old Jun 11, 2021 | 03:33 PM
Bobfit1's Avatar
Question How to remove temp control panel?
Need to troubleshoot the AC not working, and I've been fumbling around trying to get this panel out, and just can't figure it out - I'm not used to working on interiors - and am at the point where I'll likely start ignorantly breaking things trying to jimmy stuff out. Search-fu is weak.
The compressor, clutch, freon, fuses, and relay are all fine. It's something between the switch fuse and the relay, likely the dash switch, hence the need. The little LED turns on, but no power gets to the relay. I'm starting to feel like replacing the compressor would've been the easier job.
Old Jun 13, 2021 | 01:04 PM
jscene's Avatar
Go to main 3rd gen forum where there's a sticky there called "k.i.s.s. and lazy reference guide". There's some diagrams in there from I think Chilton's online about all dash removal. I don't know if that helps?
Mickeynol
Aug 3, 2022 10:44 AM
Panthese
33
Aug 18, 2020 12:08 PM
iandunham
Dec 1, 2019 05:09 PM
jojsmith
Jun 18, 2017 09:11 PM
Strastech13
Apr 22, 2017 07:22 PM
