Air conditioner stinks and Honda won't help
Old Oct 16, 2015 | 01:41 PM
Buck Fitty's Avatar
If it's the "moldy sneaker" smell, it's mold in the system, and changing the filter won't help. Kool-it, or something similar, is the way to treat it. It's supposed to be injected into the cooling system's drain, but like some of you, I don't have a lift.
By examining the shop manual (this is on my current ride, a 2008 Fit), I was able to set the levers so I could spray the foam into the dashboard's defrost vents, and it would flow all the way down to the drain. It started dripping out onto the driveway about the same time it started foaming out of the defroster vents, and I was very careful not to let any of it get on the dashboard.
One can of foam, two applications a few days apart, wait overnight before restarting, and the problem went away. A few years later, I had to repeat it.
Old Oct 16, 2015 | 03:44 PM
FitFrack's Avatar
When I open the air vent to the outside, NO air conditioner, it still smells. Now would that be the air conditioning system?
Old Oct 16, 2015 | 04:46 PM
FitFrack's Avatar
Sorry to say it was not the cabin filter. I pulled it out and it was clean.
Old Oct 16, 2015 | 06:03 PM
FitFrack's Avatar
Went back to the dealer and basically told him that I am not going away. He said ok, they will "do what they can if they can" Didn't like the "if". I take it in Monday. Will update when I have anything.
Old Oct 16, 2015 | 07:58 PM
GeorgeL's Avatar
This car is only four months old, not long enough to have a filter issue.
It's most likely a defect in the drain, either a pinched hose or a piece of manufacturing debris blocking the hose, both warranty issues.
Playing with band-aid fixes delays the ultimate fix and gives the dealer an excuse to deny warranty service.
Old Oct 17, 2015 | 12:20 AM
FitFrack's Avatar
I had those thoughts. I left in the original OEM filter since it seemed to be in good shape.
Old Oct 17, 2015 | 03:12 AM
Fit_as_a_butchers_dog's Avatar
Well keep plugging away, it certainly makes for entertaining reading.
Old Oct 21, 2015 | 06:58 PM
FitFrack's Avatar
I took it in. My dealer offered NOT to fix the problem which he was able to reproduce. Insisted I caused it in 3 short months and less than 2k miles. I drove a Saturn for years in the same fashion and never developed a problem with the air conditioner smelling....Contemplating my next move...
Old Oct 28, 2015 | 09:33 PM
GeorgeL's Avatar
Ask him to show you where in the owner's manual it says not to do whatever he claims you did to cause the problem. He won't be able to find it because it isn't there.
Or, just call Honda corporate and save yourself more BS from the dealer.
Old Oct 28, 2015 | 09:37 PM
FitFrack's Avatar
I called Honda Corp. today. I am waiting for someone to get back to me. They opened a case. They wanted to know who I took it to. I hope I don't regret telling them since that is who is near-by. I probably aced myself out of someone close to work on the car.
Old Oct 30, 2015 | 12:20 PM
FitFrack's Avatar
I kind of regret calling corporate. It will probably ruin the relationship with my Honda dealer which is only a mile away.
Old Oct 30, 2015 | 12:49 PM
  #32
Tacit Blues's Avatar
Sounds kinda like the dealer already did the relationship ruining...
Old Oct 30, 2015 | 12:51 PM
  #33
FitFrack's Avatar
Yes, and it is too bad. They are practically next door. I will probably take future problems to another dealer that is a lot further away.
Old Nov 1, 2015 | 12:40 PM
  #34
2Rismo2's Avatar
I rotated the tires today and noticed a tube near the catalytic converter. It seems that's the condenser tube. Really easy to get to. You probably don't even have to lift it, just drive it on some ramps to get enough clearance
Old Nov 6, 2015 | 01:21 PM
  #35
glhboy's Avatar
It's most likely the evaporator or condensor, I can't remember which one, most of the time it's the one that's tucked under the dash. I had a similar situation in a 2009 Scion xD I had, did everything, the dealer sprayed smell-good stuff in the car and thought that'd clear it up saying they can't do anything. I finally took it to another dealer and they knew exactly what it was and replaced it under warranty, no more bad smell.
It's basically caused by not using the fresh-air on the a/c or other heat/air options. Most folks leave it on recirculate which doesn't allow the system to get rid of the extra moisture that the system builds up, which results in mold, which results in the smell you are getting.
Take it to another dealer, call Honda, but don't accept their answer.
Old Nov 7, 2015 | 11:48 AM
  #36
FitFrack's Avatar
I sure wish you knew which one was the problem. It would help when I give them a hard time. But thanks for your input.
Old May 4, 2016 | 09:24 AM
  #37
Uncle Gary's Avatar
It's the evaporator. The evaporator is inside the car (remember from science class-evaporation is a cooling process-it absorbs heat from its surroundings). The condenser is in front of the radiator. The condenser "condenses" the R134a back into a liquid.
Old May 25, 2016 | 11:28 PM
  #38
phasfit's Avatar
A/C inadequate cooling is due to the undersized evaporator.
Old May 26, 2016 | 12:30 PM
  #39
Fit Charlie's Avatar
It's the whole system. A bigger evap won't do a thing without a bigger expansion valve, compressor and condenser. A bigger system would weigh more, take up more space and draw more power. Not good in a car that tries to do everything cheaply and efficiently.
Of course, neither is building the AC to automatically run whenever you direct the fan onto the windshield...
Old May 26, 2016 | 07:56 PM
  #40
tbFit's Avatar
Originally Posted by Fit Charlie
...Of course, neither is building the AC to automatically run whenever you direct the fan onto the windshield...
haha... Yeah, I fixed that 'feature'.
