Axlline's Fit
15 Attachment(s)
Putting this here as well to update when things change ;)
Attachment 9994 Well December time frame the heater core went out in my '99 Cherokee daily driver :/ So I convinced her that she wanted a more comfortable sedan and we got her a '14 Nissan Sentra with 12k, which made the Fit my new daily driver. Well stock is not my thing, so now the adventure stats. Picked the legit Mugens up for a steal, 16x7. Attachment 9995 Attachment 9996 Attachment 9997 Attachment 9998 While waiting for those to get here I detailed the car inside and out, shaved the rear carpet to make it look better. Before Attachment 9999 Half done Attachment 10000 Then we got snow, so the wheels didn't go on yet ;) Attachment 10001 Snow went away, got them on finally. Attachment 10002 Attachment 10003 Attachment 10004 Color matched some of the interior pieces Attachment 10005 Applied a few of "JDM" decals I got from a Japanese friend Attachment 10006 Attachment 10007 Attachment 10008 I have more plans, just need to save $$$ and decide what direction I want to go. Need to take care of that wheel gap :) I want to keep the MPG up on this on as she is my daily now. Since December my average MPG is 40.8, it was 40.9 before I put the Mugen wheels, .1 mpg is acceptable ;) Thanks for looking |
2 Attachment(s)
Here are some more pics, added som non-skid to the rear bumper to cover up scratches from previous owner :/
Attachment 9992 Attachment 9993 |
sweet! those wheels look great with this color. Looks good, dude. Get some springs on it for some lows. ;)
6 Attachment(s)
Originally Posted by wanako
(Post 1364190)
Also remembered a few more things I've done and installed pics of the trim. Stubby antenna, reversed the rear wiper, installed a "wide" blue Spoon sports rear view mirror and found this shifter "sock" in the glove box of my Prelude; some swag I got from a car show. Attachment 9985 Attachment 9986 Attachment 9987 Attachment 9988 Attachment 9989 It rained today, pardon the dirt ;) Attachment 9990 |
i'm liking that Spoon rear-view. Seems very useful.
If I may ask, why did you reverse the rear wiper? any advantage to that? It's the first time I've heard of it. |
1 Attachment(s)
I did it to be different, rumor has it, that it "might" make the blade last longer, because you don't get the build up of dirt on it like you would in the oem position, but hey, to each his own :D Several of the 2nd gen guys have done it, I used their writeup.
I also swapped out the cabin air filter today. I am go to assume that this is the oem one from the factory, LOL! Attachment 9977 |
9 Attachment(s)
So while admiring my wheels, I got tired of seeing rust and bare metal behind them. On Saturday, the weather was warm enough to ceramic coat the brakes, not much of a write up just some before and after. I used the same(Dupli-color caliper coating) on my Prelude back in 2012 and it still looks great.
Attachment 9965 Forgot to take a before of the rear drums, here's mid way through cleaning with a wire-wheel Attachment 9966 Attachment 9967 Attachment 9968 Attachment 9969 Attachment 9970 Attachment 9971 Attachment 9972 Attachment 9973 |
those wheels look so sweet!
Really like your trim piece color mod... any pics or info on the removal process? Can they be carefully pried out without removing the dash?
es |
Hows the spoon rear view mirror compared to the stock one? I was thinking about picking one up
8 Attachment(s)
Originally Posted by Ryfle
(Post 1365036)
(Post 1365013)
Originally Posted by stembridge
(Post 1365019)
es Step one, pull the gauge cluster surround; by putting you fingers under it just above the steering column Attachment 9957 Attachment 9958 Attachment 9959 Attachment 9960 Then you can see the complete trim pieces Attachment 9961 Attachment 9962 Start prying with your finger or a non-marring(plastic) tool where my fingers are and work you way outboard. Attachment 9963 Attachment 9964 Hope it helps, just take it slow and easy. |
Awesome - looks pretty simple. Thanks!
es |
10 Attachment(s)
So I polished the window visors, the rear plastic garnish and the tailights. Bringing a used car back to where it should be.
Before Attachment 9939 After Attachment 9940 Attachment 9941 Before Attachment 9942 After Attachment 9943 Before Attachment 9944 After Attachment 9945 Also blacked out the rear wheel wells Attachment 9946 Attachment 9947 Attachment 9948 |
nice work! the polish really did the trick. Did you wet-sand or just polish?
(Post 1365562)
14 Attachment(s)
So my mileage on the Fit after the first month and a half was 40.9mpg(on 87). I decided to try something. So, the last two tanks, I filled up with premium(92 octane). Mileage jumped to 43.5mpg. Noticed when we bought the Fit the under engine aero cover was missing(had been ripped off). The cheapest I've found the replacement for is $149https://www.facebook.com/images/emoj...1/16/1f62e.png😮 You can see in the photos where the hardware was ripped away, well I had this piece of aluminum that's about the right size. Today's project, fix the"aero" hole https://www.facebook.com/images/emoj...1/16/1f61c.png😜 The front 2 hole in the aluminum panel lined up perfectly, yay no drilling in the heat treated aluminumhttps://www.facebook.com/images/emoj...1/16/1f61d.png😝 Wanted it sort of quick to remove but secure, so I made these finger that you wedge the panel in between those an the frame. I used the 2 middle holes as opposed to the original mounting spots because I could easily get to the back of these 2 holes. To remove, just remove the front two screws and pull forward(for oil changes). Had a slight gap at the front, so I took an air dam I had from the wife's old car. Reshaped it to cover the gap. Now to see if there are any mileage gains https://www.facebook.com/images/emoj...1/16/1f61c.png
http://img.photobucket.com/albums/v2...84C81D2ADB.jpg Attachment 9910 Attachment 9911 Attachment 9912 Attachment 9913 Attachment 9914 Attachment 9915 http://img.photobucket.com/albums/v2...6DD6F59D95.jpg Attachment 9916 Attachment 9917 Attachment 9918 Attachment 9919 Attachment 9920 Attachment 9921 Attachment 9922 Attachment 9923 |
that's a great idea, actually. well done!
(Post 1366082)
Good job. I'm curious to see if it affects your mileage. There are some who thinks it makes no difference.
1 Attachment(s)
I am curious too, This was the first trip after I filled up and reset the trip meter. I know way too soon to be overjoyed and preaching, lol. I know it will go down, but it's the highest I've ever seen on my Fit.
Attachment 9909 |
| All times are GMT -4. The time now is 05:16 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
