Need help deciding on tire size for 15" wheels and summer tires.
Old Mar 6, 2024 | 08:56 AM
urs1ne's Avatar
I have a 2017 EX. I am going to get some 15" Konig Hypergrams. I have a second set of wheels and tires for winter so I want to get something more on the performance side for summer. I was thinking maybe 195/60/15 or maybe even some 205/55/15 since those would keep me close to the stock size. I just wanted to check here first since I know choosing a good tire size can make or break the amount of options available. I mostly do city driving so I am not too worried about MPG. I do plan on installing Swift springs down the road in case that is a factor. What tire size would you guys suggest?
Old Mar 6, 2024 | 11:11 AM
Drew21's Avatar
What's your new rim width? A quick check of the Konig website suggests that the Hypergram 15 inch comes in 7.5, 8, or 8.5 inch widths.
A bit more Googling will show you recommended tire and wheel width combinations. Unless you want to do something extreme, I would stick with these ranges, in which case 195/60R15 tires would not be recommended (too much stretch) and 205 mm width tires barely squeak in as the minimum tire width for 7.5 inch width rims.
Old Mar 6, 2024 | 11:53 AM
urs1ne's Avatar
That's extremely helpful, thank you!
Old Mar 6, 2024 | 12:12 PM
urs1ne's Avatar
Looks like I'll be going with Konig Helium 15x6.5 +40
Old Mar 6, 2024 | 12:46 PM
balucipher's Avatar
I run 15x7 konig Heliogram +35 with 205/50/15 Yokohama AD09s
Old Mar 6, 2024 | 12:56 PM
urs1ne's Avatar
Wow, those are much lighter than the Helium, I think that is the way I'm gonna go.
Old Mar 6, 2024 | 07:49 PM
balucipher's Avatar
I think the hypergram is slightly lighter and the Enkei RFP1s are the lightest, they're like <10lbs
ChrisOwnsAHondaFit
Oct 12, 2021 10:35 AM
timmer21
Aug 24, 2020 04:31 PM
utsug
Feb 17, 2017 09:44 PM
FitfulKenny
Sep 27, 2015 05:03 PM
hoss10
Mar 31, 2011 09:28 AM
