Curb rash:((
Old Mar 12, 2015 | 09:03 PM
Kdawgz's Avatar
Curb rash:((
I was making a right turn and didn't notice a 3 inch lift on the concrete (Michigan is the worst). I got a very bad curb rash. Now instead of getting the same rim, I was considering replacing all four rims. Any suggestion's for 17" hfp rims with tanabe shocks? (preferably a grey color) I don't know which ones will fit.
Also, I couldn't fit the part number for the EX rims
Old Mar 12, 2015 | 10:58 PM
GeorgeL's Avatar
Find a good wheel shop that works on curb rash and let them take a look at it. Sometimes they can do amazing things with what looks like a hopeless case.
This is one reason that I always put tires with a bit of sidewall on my cars. When the rim extends beyond the tire it is pretty much inevitable that it will get scraped. Being careful only takes you so far.
Old Mar 13, 2015 | 07:13 AM
GoBucky's Avatar
I had the same issue with a previous car that had very low profile tires and alloy wheels that hung out there, exposed. I agree with George, I would get a quote from a shop for the repair first just to see what it would cost (it will definintely be much less expensive than new wheels). That is, unless you are looking for an excuse to upgrade.
Old Mar 15, 2015 | 10:39 PM
Kdawgz's Avatar
But....is it truly cost effective? I don't have shops around here that fix curb rash
Old Mar 15, 2015 | 11:16 PM
GeorgeL's Avatar
Google is your friend:
https://www.google.com/search?q=michigan+wheel+repair
As far as effectiveness, get an estimate and compare it to the cost of a new factory wheel, a wheel from a wrecker, or a set of new wheels.
Personally, I prefer steel wheels with tires that are wide enough so the rim never touches the curb. Those silly rubber band tires and protruding rim edges look great on SEMA cars, but the real world demands something less flashy and more useful.
Old Mar 18, 2015 | 12:36 AM
Fit_as_a_butchers_dog's Avatar
Yep, wheel repair is worth it. Had it done and amazing results. Just find someone with enough experience.
Old Mar 24, 2015 | 12:54 PM
DaBinChe's Avatar
Also next time you get tires make sure you get some that have the rim/lip protector.
Old Mar 28, 2015 | 03:43 PM
mikeDF's Avatar
Good advice. I always choose my tires very carefully. A lot of them have some sort of rim protection and some better than others. I had Toyo Proxes 4 at one time and rubbed the tires against concrete borders a few times with zero damage to my aftermarket wheels. It doesn't look quite as good as tires that don't have it because they have a thick rubber lip all around the wheel but you will love them when they save your expensive setup a few times.
HotIron
New England Community
Jun 4, 2012 01:29 PM
Luichenwai
BernardiParts.com
15
Oct 28, 2010 07:21 AM
Fitamusprime
May 6, 2009 07:53 PM
Spoon-Fit
Nov 20, 2008 02:14 PM
pwnstar
May 18, 2008 03:25 PM
