Anyone running 205 wide tires and experiencing front suspension rub?
Old Sep 8, 2015 | 11:38 AM
StreetFit's Avatar
I recently put on a set of 205 tires on my stock EX rims. For the most part they're great and the car feels a lot more stable especially at fast highway speeds.
The only negative I have is when i hit a big bump like a pot hole you hear a terrible suspension clunk up in the front. I think it's hitting the the front struts on big dips. After inspecting the wheel well I can see the tire sits right below the front strut and only has about 2 inches of travel before it hits. I'm just seeing if anyone else had this experience. I really only had the car for 1k miles before i switched tires so i don't remember if it did that before but i do suspect the wider tires makes it more likely to rub. You probably wouldn't noticed this issue if you live in a state where theres good roads but in the North East it's hard to avoid some big holes.
Old Sep 8, 2015 | 01:25 PM
jhn's Avatar
jhn
205/50/16?
Old Sep 8, 2015 | 01:36 PM
StreetFit's Avatar
Yes, 205/50R/16 is what i'm running. I'm just wondering if anyone else has a similar experience with the wider tires.
Old Sep 8, 2015 | 01:58 PM
stembridge's Avatar
I have 16x7 wheels, running 205/50R16 Continentals, and if I hit a big bump, will hear the front wheel making contact briefly. It's hitting the inner lip of the wheel well/fender right at the top – actually hitting the wheel well liner. Rolling the fenders would probably alleviate this. Or moving to a State with better roads.
es
Old Sep 8, 2015 | 06:05 PM
Uncle Gary's Avatar
Well, don't move here. The "vampire state" has let the roads deteriorate for the past 10 years. They're past the point of uncomfortable, and are now dangerous.
Old Sep 8, 2015 | 06:14 PM
StreetFit's Avatar
I wasn't sure if it was rubbing the fender lining or the strut. I may need to chalk it up to see where exactly its making contact.
NYC is the worst, right now it's summer time so the roads aren't too bad i might only rub once in a blue moon. But after it snows and the snow plows destroy the streets its going to be rough.
Old Sep 9, 2015 | 09:41 AM
stembridge's Avatar
I live in one of the poorest counties in one of the brokest States (IL)... if we're lucky, we might get a shovel or two of gravel thrown in the bigger potholes every so often.
es
Old Sep 9, 2015 | 11:19 AM
jhn's Avatar
jhn
I doubt it is the strut. The strut body is bolted to the knuckle and moves with the wheel. The tire can't make contact though the travel stroke unless something is loose. If it makes contact, it will always make contact.
I just ordered some 205's and I'll get back to how they mount up. I do not anticipate any issues though.
Old Jul 18, 2019 | 11:50 PM
iAmFinatic's Avatar
es
I run 205/55/16 and don’t have any issues with rubbing. Rims are 16x7
Old Jul 19, 2019 | 10:03 AM
wasserball's Avatar
Or, you can move to Germany where roads and autobahns are as smooth as a bowling ball alley.
Old Jul 19, 2019 | 12:07 PM
Those are stock 2012-13 Fit Sport wheels. They are not 16x7.
Also 205/55/16 are too tall.
Old Jul 19, 2019 | 12:18 PM
silverrose12's Avatar
would this happen to ppl lower their a little bit ? i used RS springs and the car sits little lower..
also, would offsetting the rim further out would help?
txmatt
Mar 23, 2021 04:55 PM
dasautoatheart
Dec 10, 2012 02:37 PM
JDM-Taffeta-S
Aug 18, 2011 10:05 AM
Ducke
Aug 17, 2011 01:48 PM
fung88
Jun 15, 2010 11:20 PM
