Fit I.C.E. Threads discussing in-car electronics including audio, video, security, and navigation systems for the Honda Fit/Jazz
Anyone ever use this grommet as a passthrough?
Old Feb 21, 2019 | 11:23 AM
evanphi's Avatar
I passed my trigger wire for my aux lights through the hood release cable grommet. There's this other one beside it that looks like it also goes to the cabin. Seems like a lot less involved than going through the firewall.
Old Nov 2, 2022 | 11:46 AM
Maurtis's Avatar
Resurrecting this thread since I could not find any other info on this grommet.
YES!!!
I ran an 8 gauge power wire using this grommet, on the other side is just insulation that you can poke through with a screwdriver easily. Drilled a snug hole for the cable through the grommet and routed the cable from the battery (zip tied to the hood release cable to prevent the cable from rubbing on the fender), down into the fender area, through that grommet and into the cabin. I then used sealant to glue the grommet back in place and seal the cable hole just to be safe.
To access the grommet area you jack the car up for better clearance and remove the pins holding the fender liner in place. Peel back the fender liner and the grommet is right there.
evanphi
Jan 27, 2021 08:55 AM
evanphi
Feb 20, 2019 09:56 PM
oic929
Jul 1, 2017 02:14 AM
Black3sr
Nov 17, 2011 07:40 AM
