Initial Tank From Dealer?
Old Apr 9, 2019 | 09:34 AM
jpm's Avatar
jpm
Is there anything special about the initial tank of gas you get from the dealer? I traded in my 2016 Fit LX for a 2019 Fit EX, and my initial tank of gas has been incredible so far. I've gone 98 miles and only two ticks are gone from my gas gauge with an estimated 359 range left. Now, with my 2016 I'd often get a crazy range on a full tank but it would always be lower by the end of the tank, however by 100 miles on a tank I'd always have 4-5 ticks of the gas gauge gone. If it was just a crazy range estimate left I would just assume there would be an eventual large drop off, but only two ticks gone for 98 miles is impressive. Does the dealer fill it with special gas (pure gas maybe, non-ethanol) or something?
Old Apr 9, 2019 | 12:28 PM
wasserball's Avatar
The gas gauge indicator is not linear, nor is the average mpg display accurate. Find another way of calculating your mpg.
Old Apr 9, 2019 | 12:47 PM
woof's Avatar
+1
It may have been filled up with premium gas which often does not contain ethanol and will usually give better gas mileage than regular, but as mentioned, don't draw any hard conclusions from the gas gauge. When you start filling up you can use those numbers for a more accurate estimate of what you're getting.
Old Apr 10, 2019 | 12:17 AM
JingJangJoe's Avatar
The fuel gauge and the calculation done by the trip computer is always off. Do not believe in it. I just calculate 2/3 of what I see on the trip computer for the range remaining with the amount of fuel
cavernap
Aug 13, 2018 02:41 AM
fitchet
Jan 27, 2017 03:20 PM
Sean Passmore
Mar 9, 2015 12:12 AM
Odie
May 11, 2011 02:14 AM
sw20
May 22, 2006 04:49 AM
