Honda Fit feels very loose in the rear
Old Jun 11, 2019 | 02:00 PM
Safehandle's Avatar
I have a 07 base model and when I turn the wheel back and forth it feels like the rear end is swaying around and loose. I checked my tire pressure and it seems good, I also recently got an alignment. The car has almost 180,000 miles and I’m wondering if maybe my shocks are blown? Or maybe something is loose in the rear torsion beam? I’m not too familiar with the Honda Fit suspension but any input is appreciated
Old Jun 14, 2019 | 09:43 AM
Alco RS-1's Avatar
If they are original, your rear shocks are most certainly worn out after 12 Years and 180K Miles. You should replace your front shocks/struts too. A shop would likely recommend new tie rod ends and bushings too. Aged rubber suspension parts will be worn, cracked, hardened, etc.
Notsofitmike
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Nov 19, 2019 04:18 PM
mrphilip
May 17, 2017 08:55 PM
ralphch
Jan 7, 2017 11:10 PM
fit2bking
Apr 29, 2015 06:37 PM
Skimmer
Feb 8, 2008 05:50 PM
