2010 fit rear Shocks
Old Aug 26, 2019 | 07:10 PM
Dominicdx's Avatar
Hello does anyone know if the Honda Fit shocks are same as Honda Insight?
going to use the Rear Honda Insight Coil Springs. But was not sure if Shocks are the same
thank you.
Old Aug 27, 2019 | 08:37 AM
fit09's Avatar
Can’t answer your question about Insight shocks being compatible with a Fit. Why are you replacing the springs ? Seems like a waste of time and money unless there’s a problem. I just replaced the rear shocks on my 09 that has about 140K miles with the KYB shocks. Shocks made a slight difference in ride quality but I was not expecting a huge difference either. I also have a aftermarket rear sway bar and that did improve the body roll of the car in turns.
Old Aug 27, 2019 | 09:12 AM
Dominicdx's Avatar
Lift
Hello I seen in another post if you use the Insight Springs it will lift the car 1” or more. As due to the battery pack in a Insight.
so I didn’t know if the shocks were compatible
or if the Insight would give the car better ride quality
ill be having tools in the back so just wanted to be over prepared for the weight
Dominicdx's Avatar
Sway bar
Where did you get aftermarket sway bar
Old Aug 27, 2019 | 09:44 AM
fit09's Avatar
See this link for the sway bar, looks like it’s out of stock right now.
https://www.kseriesparts.com/PRO-62-1061.html
Now sure how much weight you are talking about but new aftermarket shocks might just work for you.
But I like to save money whenever possible....
Old Aug 27, 2019 | 09:52 AM
Dominicdx's Avatar
Thank you, I found Springs for 40$ total so it should be a cheap mod.
how are the KYB shocks?
only options in my area are KYB or Monroe OEM.
Old Aug 27, 2019 | 10:15 AM
evilchargerfan's Avatar
you failed to mention, 1st gen, 2nd gen, or 3rd gen insight
no useful info from me either way, but I'm curious of the outcome
Blackberry Goose
May 5, 2020 02:50 PM
fit2bking
Apr 29, 2015 06:37 PM
Bean_Garage
Jul 28, 2014 06:04 PM
linnboi
Dec 2, 2012 12:19 AM
Skimmer
Feb 8, 2008 05:50 PM
