[CrossPost] Strut / Shock / Valve Adjustment How To Guides
Old Oct 16, 2019 | 02:25 PM
Globalksp's Avatar
I'm heading into a DIY garage tomorrow to take care of some work on the Fit. Since I have no driveway / garage / tools, yet, still like to turn the wrenches myself, the DIY garage seems the way to go. What's different, of course, is that I'm paying ($30) per hour and if something goes wrong, I can't simply leave the car for the night and come back to it the next day. So, I'd like to go in as prepared as possible. I have a lift reserved from 10AM-6PM, yet it still feels like a lot to accomplish.
If all goes well, at the end of the day tomorrow, I will have:
  1. Replaced the shocks, struts, strut mounts, and the sway bar bushings (retaining the original springs)
  2. Adjusted the valve clearances (maybe not worth paying the $30/hour to do this as it doesn't require a lift)
  3. Changed the motor oil+filter
  4. Changed the trans fluid
  5. Rotated the tires
For the suspension work and the valve adjustment, I'm looking for How To guides and/or videos to get me up to speed and to know what tools I'll need ahead of time. I've found the following, but, if any of you have links to better / more accurate tutorials, please share.
Struts
Shocks
Sway Bar Bushings
Valve Adjustment
Finally, if there's anything else I should consider swapping out (that I can get the parts for today) or checking while I'm there, I'm all ears.
Thanks.
Old Oct 17, 2019 | 11:29 AM
JerryHughes's Avatar
Thank you for the links and info!!!
Globalksp
Oct 29, 2019 05:40 PM
Globalksp
Aug 11, 2019 08:35 PM
Globalksp
Aug 8, 2019 01:39 PM
bigalttd1
Apr 29, 2015 11:25 PM
Mynodha
Jul 17, 2014 01:25 AM
