Resetting Engine Oil Life Display
Old Nov 16, 2019 | 08:18 PM
AFittingEnd's Avatar
I recently bought a 2009 FIT. In anticipation of a long road trip I changed the oil, even though the Engine Oil Life Display indicated only 20%. I am now having trouble resetting the display indicator.
The owner's manual says to hold the reset button for ~10 seconds, at which time the oil life display will start blinking. It does...
The manual then says to hold the reset button for another 5 seconds, which will cause the display to reset. In my case, it does not. If I hold it long enough, maybe 20 seconds, the display quits blinking and reverts to the original non-blinking display of 20%.
Can anyone suggest what I need to do to reset the Engine Oil Life Display?
Thanks
Old Nov 16, 2019 | 08:42 PM
Brain Champagne's Avatar
I'm not sure but you might have to release it and then push it in again and hold it. Try that, see if it works. If I remember right the manual wasn't clear but there was some way to make it work.
Old Nov 16, 2019 | 08:57 PM
You are exactly right
After the blinking has commenced, you have to release, then immediately re-press the button for another 5 seconds.
Muchas Gracias !
PS
Thanks to you I'm loading a Hanukkah app into my FIT.
Farrago
Sep 17, 2017 11:39 AM
VodkaAlan
Nov 25, 2010 10:40 AM
Edison Carasio
Mar 30, 2010 09:02 AM
vwli
Jan 17, 2010 01:47 PM
Taffeta Fit
Apr 16, 2009 11:21 AM
