08 fit driver side rear door no power
Old Dec 3, 2019 | 10:36 PM
Jonbond67's Avatar
Exclamation 08 fit driver side rear door no power
My daughters 2008 fit drivers side rear door has no power at all ! No window no door lock and no sound from the speaker . I’m thinking there is a wire harness that is unplugged. Everything inside the door is plugged in, does anyone have a suggestion as to where another connection is ?
Old Dec 4, 2019 | 09:18 AM
marmaladedad's Avatar
Have you checked the fuses? Was the rear door ever worked on, say after an accident?
It is not too difficult to remove the rear door card/panel. You could remove it quite easily to check if the connectors are plugged in.
Old Apr 5, 2024 | 10:16 PM
timayarlay's Avatar
Hey, If you happen to see this, I currently have the same issue. Please respond if you recall the resolution of this problem. THANKS
prisonrodeo
Oct 23, 2016 09:20 AM
inspires121
Feb 24, 2015 05:17 AM
CptanPanic
Oct 6, 2014 06:00 PM
randomracer
Mar 13, 2008 07:26 PM
acctforjunk@yahoo.com
May 4, 2005 04:44 PM
