catalytic converter - which one
Old Dec 4, 2019 | 08:55 PM
georgi6's Avatar
Hi guys , could you recommend me a catalytic converter from your personal experience?
There are non expensive brands sold by Napa, Autozone, O'Railly (around $350).
No need of CARB catalytic converter.
Old Dec 6, 2019 | 01:34 PM
NEGD3's Avatar
I just put a “Bosal” brand one in my 08’
i think it was 175$ from rock auto.
Fitment wasn’t 100% perfect - It’s super close to the swaybar at full droop. But its fine once it’s on the ground.
Old Jan 4, 2020 | 10:53 AM
exidor12's Avatar
hey NEGD3,
are you happy with your bosal cat? did you do it to fix a p0420 code? if so, did the code go away?
thanks!
kyle
Old Jan 4, 2020 | 12:34 PM
NEGD3's Avatar
I had no codes. My cat was just very rusty and had an exhaust leak so I replaced it, im happy with it
Old Jan 4, 2020 | 02:38 PM
exidor12's Avatar
ah okay, thanks for the info!
Old Feb 28, 2020 | 10:59 PM
georgi6's Avatar
I bought MagnaFlow California Catalytic Converter 5461767 for $440.
Installation notes
New replacement bolts (cat to muffler) 3x17mm, tread M10-1.25 class 8.8(grade 5) came with cat, but no bolts. Found in AutoZone 8.8 in O’Reilly 10.9. Make sure the old gasket from the top pipe (springs) is removed. Labor time 2hs. Deleted the code with a scan tool.
Bolts and nuts
3x14mm 24 lb. Ft, pipes cat to muffler; rusted, Sprayed 2x with penetrating oil didn’t help. Used impact wrench (electrical) to remove rusted bolts.
4x10 – shield to cat – not applicable for the new cat
2x12 top pipe to the engine - 16 lb. Ft
1 oxygen sensor 22mm (special tool rent) – 33 lb. Ft
Old Feb 29, 2020 | 01:19 PM
exidor12's Avatar
Installation notes
Bolts and nuts
great thanks georgi!
doctor J
Oct 21, 2019 05:53 PM
aboutblank
Jul 19, 2018 05:44 PM
TheDoughboy
Feb 16, 2018 08:19 AM
Hirotirta
Jul 21, 2010 05:48 PM
Hirotirta
Asia Fit Forums & Clubs
Jul 19, 2010 06:08 PM
