Enkei Er tarmak 15x5 et45
Old Jan 18, 2020 | 01:48 PM
Cmos's Avatar
Hello from Greece.
I have a 2005 GE3 fit (jazz here) and i i recent bought a set of used wheels from a suzuki ignis sport. They are very lightweight and supposed to be the correct offset for my fit but when i put them on i found out that the inner side of the spokes hit the front calipers. My question is how thick a spacer can i use so as not to have problems with the stock studs? I belive i can go up until 5mm? Is that correct?
Old Jan 23, 2020 | 08:35 AM
knope's Avatar
I would guess, so long as you:
  • can still torque the lugs on to spec
  • center the wheel, and spacer, on the hub
it should be fine...
Old Jan 23, 2020 | 03:19 PM
Cmos's Avatar
Finished product
It is done...
Also the new wheel with tyre is 12,9 kg. I saved 700 grams per wheel compared with the 14" i had before.
phenoyz
Oct 7, 2015 02:02 PM
lakia5524
Feb 8, 2013 09:51 PM
crazyray
Aug 6, 2010 11:02 AM
mahout
Nov 23, 2008 05:59 PM
Chitownfit
Jun 26, 2008 09:28 PM
