L15 Intake Manifold (Increase CFM)
Old Mar 1, 2020 | 09:06 AM
H.V's Avatar
H.V
Hello everyone,
As the stock throttle body can flow more than enough for a NA application, the intake manifold is the most restrictive point of our engine.
The goal of this post is to find a solution to implement the proposed improvement of the airflow for the stock intake manifold.
- The problem
The stock intake manifold is very restrictive internally.
It's chocking the engine at high rpm (it simply doesn't flow enough)
Internal view of the restriction
Cutaway of the intake (image from Honda 2009 Fit Powertrain - Media Newsroom Press release )
- The solution
- The implementation
We need to find a shop that can work with Plastics/Fiberglass to open the intake, cut the restriction and work the bottom/upper plenum.
Let's get the ball rolling and find an affordable solution to this problem.
I'm certain that this can unleash quite some power at high rpm.
Old Jun 1, 2020 | 12:18 PM
H.V's Avatar
H.V
No one is interested?
Old Jun 1, 2020 | 07:43 PM
Rap SantOs's Avatar
Why would you remove that,, it was put there as it equalizes air inside and to keep all cylinder get same air flow,, if you remove that one or two cylinder doesnt get enough air and youd have a rough revving engine
Old Jun 1, 2020 | 07:46 PM
Rap SantOs's Avatar
The 2 cylinder near the tb gets good air flow while the last 2 cylinder is fighting for air from the 2 cylinder near the tb
Old Jun 1, 2020 | 09:36 PM
GolNat's Avatar
Power gains?!? I'd be shocked if that gave you anything.
Old Jun 29, 2020 | 10:31 PM
Z062FIT's Avatar
Ported intake manifold
Originally Posted by H.V
Hello everyone,
- The problem
- The solution
I ported mine at home. Immediate improvement. There is a company in Turkey that does it if you send yours to them...
Bongobennie
Jun 14, 2016 11:51 PM
integradriv3r
29
Mar 14, 2016 04:10 PM
valhalla
Jul 15, 2012 10:13 PM
valhalla
Jul 5, 2012 07:57 AM
tonyrace_41
Jun 21, 2006 09:55 AM
