Quaife ATB LSD available for Fit?
Old Dec 9, 2006 | 04:22 PM
spoonek4's Avatar
I was reading about the Skunk2 Fit earlier and I see that they have a Quaife LSD on their turbo Fit.
Is that just a prototype LSD or it's just using some other honda model's LSD(for example a SOHC motor civic)?
I really hope Quaife will make a LSD for Fit....
Anyone got information regarding to this?
Old Dec 9, 2006 | 05:27 PM
JamesBizzle's Avatar
i'm looking for answers on this as well.
Old Dec 9, 2006 | 06:53 PM
MINI-Fit's Avatar
I've searched but didn't see much for Quaife for the FIT.
I did find Cusco differentials for the FIT
http://www.modacar.com/products/Hond...erentials.html
1.5 and 1 way diffs for $979
Old Dec 9, 2006 | 08:24 PM
spoonek4's Avatar
Yeah I know cusco, spoon, j's racing, ATS etc do make LSD for Fit. But if Quaife do make a unit for Fit. I will go for Quaife.
Old Dec 10, 2006 | 01:35 PM
MINI-Fit's Avatar
What are going to use your FIT with Quaife for?
Who is going to do the Quaife install?
Are you thinking of upgrading to racing clutch and lightened flywheel at the same time?
I've been searching and did not see any mention or listing of Quaife for the FIT. I searched UK sites for Quaife as well.
Have you owned a previous car with Quaife installed? Did it make a difference for you?
Old Dec 10, 2006 | 04:00 PM
spoonek4's Avatar
Yeah I've emailed clutch master & ACT about clutch/flywheel issue. However, only ACT replied(both sales rep & manager as far as I remember). They would probably have something available summer 07 on clutch.
Which I'm considering ATS carbon clutch as well.
I had ITR LSD on my 00' EM1 civic before. I use my car for daily driving, autocross & HPDE. It's such a BIGGGG difference with & without LSD. Even a stock unit gave so much more fun compare with running open diff! I've searched around and I don't think Honda did put LSD as an option for the Fit so my only hope would be aftermarket units.
Most of my friends like the Quaife unit, and it's hard to beat their warranty coverage!
Old Dec 10, 2006 | 04:31 PM
MINI-Fit's Avatar
Quaife is good anytime you need more traction on a decent surface(not ice or mud).
Track, drag strip, Driving school or autocross are all good opportunities for an LSD to help. Quaife is quite durable but it isn't cheap and labor to install it tends to be costly.
I have found that novice drivers might not see much improvement of times on the track until they get enough skill to make good use of the Quaife.
I do think that Quaife is also helpful during times of bad weather or on bad surfaces when traction is less than ideal. It's passive and works all the time to assist.
A durable racing clutch is always good, and be careful not to go too light on the flywheel (moderately light is more usable/durable for street use and not so noisy). Save installation costs by installing Quaife, flywheel and clutch all at the same time if possible.
Old Dec 10, 2006 | 10:39 PM
spoonek4's Avatar
Yeah I know what u mean. I wanna put as much power to the ground as possible. So clutch & LSD is on my list. I'm agree on the flywheel part. I might just shave the stock flywheel coz flywheel that's too light don't seem to help on daily commute. I want something that's useful, fun and easy to maintain.
I enjoyed my civic so much after I put in 98spec 4.785 FD set & the ITR LSD. It just feels like two different car. Yup that bumped me into a different class in autocross. But that's 110% worth it coz I can feel the difference pretty much EVERYDAY. Especially when it's raining or snowing.
So I really really hope Quaife will make a unit for the GD3. If they do, I guess some of my friends would line up for it!
Old Dec 11, 2006 | 11:00 AM
carlosalicea's Avatar
check out with skunk2 bucause I recall them stating that they use a RSX one
Old Dec 11, 2006 | 12:42 PM
FITFANATIC06's Avatar
I sent my spare tranny to Quaife for the R&D. It should be ready for us (Jackson Racing) to test in February. I will keep you guys posted.
As far as I know, nobody has a Quaife for the stock trans.
Old Dec 11, 2006 | 01:04 PM
lanakano's Avatar
Is there a wieght difference between the LSD and Open Diff? If so how much?
Old Dec 11, 2006 | 01:21 PM
Quaifes always end up weighing more because they are overbuilt and much more complex. I'm not worried about weight, just traction on the track!
Old Dec 11, 2006 | 02:01 PM
spoonek4's Avatar
Originally Posted by lanakano
Is there a weight difference between the LSD and Open Diff? If so how much?
Save the weight else where. For example the driver which is FREE! Well hope they will have something available next summer or so.
Old Dec 14, 2006 | 01:41 PM
spoonek4's Avatar
Anyone else heard anything regarding to Quaife LSD's availability?
Old Dec 15, 2006 | 02:07 PM
AJ PwR Jr.'s Avatar
Former Vendor
You know the Quaife will not work any better than clutch type LSD so why don't you consider ATS carbon ? I just had one in my friends DC5 and it is quiet and I think the life span is much better than normal clutch type
Old Dec 15, 2006 | 03:43 PM
KnifeEdge_2K1's Avatar
or why not go torsen or helical type diffs
Old Dec 16, 2006 | 01:28 AM
spoonek4's Avatar
Tks Ben for your input. I'm doing some research on these stuff now. Still haven't really pick one yet. But it will be either ATS or Quaife.
KnifeEdge_2K1: U know which brand do make helical or torsen type LSD for our cars?
Old Dec 16, 2006 | 01:34 AM
nope, but ill let you know if i find out, all i know is j's racing makes a 1.5 lsd, or it mighta been jackson racing ... not sure
Old Dec 16, 2006 | 01:56 AM
spoonek4's Avatar
Yup I know J's racing, SPOON etc make one but I don't wanna go for metal clutch type LSD.
Old Dec 16, 2006 | 02:15 PM
AJ PwR Jr.'s Avatar
Former Vendor
Helical type normally are a lot milder than clutch type and they don't hold up as well. For performancewise, I will rate a clutch in better in all way. I used to have the stock Integra Type-R transmission with helical LSD in my Civic and once I replaced to the Spoon 1.5 way clutch type, it made a lot bigger difference during turn and acceleration.
The down side about clutch type LSD (metal plates) is they will make a bit of clunking sound and you have to replace the tranny fluid (LSD Oil)quite often and the life span of it is shorter than the helical. IMO, if the LSD doesn't wear = it is not working to put down the full potenial of the car just like grippy tires always wears faster
From the new technology, ATS has developed carbon plates to work inside their LSD. Carbon will wear down a lot slower than metal and it doesn't make as much sound. And ofcourse, it will cost more
