Honda CR-Z Suspension on Fit, a New Discovery!!
Old Jan 31, 2021 | 09:19 AM
Fit Hybrid RS 2012's Avatar
Hello Guys, You may know me,i own both k-swapped Cr-Z and a Fit. Both are turbo. Point of this post is.
My Fit was an hybrid,when i did K-Swap the rear was lifted way higher because 170 LB batteries were no more in rear. I installed Tein coilovers but they were too low for my taste, even on highest settings. Because roads are rough here and speed bump/breakers are huge. Car hit every one on them.
On CR-Z i am using Tanabe's coilovers. One day i was in my garage storage room and both stock shock & springs were there,I put them side by side and viola, the crz were 1.5 inch shorter and springs were stiffer. They were boltons. Now i have no more worries about dampers under stress because those CR-Z springs and shocks/dampers are meant for each other.Not like people use lowering springs which put much stress on OEM shocks.
From net search i know the Honda Fit GE body is stiffer, thats why Honda used softer suspension to make ride quality comfortable. CR-Z body is not so rigid so Honda made its suspension stiffer. So now we have a better & cheap alternative than those lowering springs which put stress on OEM shocks. And more handling too. You can find stock CR-Z ones cheap online becasue most of CR-Z guys are on coilovers.( Don't share this post to CR-Z guys or else the rates will go higher :P )
Here are the springs rates.
CR-Z 2011.(Dont know about upper models)
Front : 2.2kg/mm
Rear 3.4kg/mm
Honda Fit/Jazz Ge(2008-12)
F1.7k
R 2.0k
For those who are thinking
Fit GD has spring rates of F 3.1 / R4.9.
CR-Z vs Fit Shocks/spring comparison
Left Fit ,right CR-Z
Fit left , CR-Z right
It gives it that stance look and dont hits the bumps so often and has OEM Honda reliablity and more handling. Best of both worlds
Old Jan 31, 2021 | 10:53 AM
hmarkop's Avatar
This is a absolutely GREAT find----but there is one question: is your GE exactly the same as our GE in North America? I think the answer is LIKELY but some confirmation would be nice!
DId you happen to take any pictures of the front struts comparisonS?
Correction: KYB makes aftermarket dampers for the CR-Z (but no "Strut Plus")
Old Jan 31, 2021 | 11:03 AM
The USA Fit has longer nose(hood/engine bay) to meat USA safety rules. Other than that same.
I have kept both front springs/shocks same as they were because for traction in FWD car rear needs to be stiffer than front so that when car accelerates the front is not lifted and tyres loose traction. Thats why in both my rides fronts are OEM ones. You know K24 Turbo @ 511hp and 400 WTQ is a lot for a FWD. Thats why...
Old Jan 31, 2021 | 03:58 PM
hmarkop's Avatar
I think I would want to swap the FRONT too, I think the loosy-goosy sway and movement of my fit has more to do with the front than the rear.
What do you know about the CrZ and GE8 FRONT strut compatibility, is it also just bolt-on ? ?
WHAT I WANT TO DO IS TO UTILIZE THE SHOCKS AND DAMPERS FROM THE CRZ WHICH ****PRESUMABLY****** ARE VALVED STIFFER TO HANDLE THE STIFFER SPRINGS
AND TO USE THESE SHOCKS AND DAMPERS FOR A LOWERING SPRING!!!!!!!!
MAKES SENSE RIGHT??????
Old Jan 31, 2021 | 09:25 PM
Exactly thats my point. We have a OEM Honda Option for better handling and lowering car height. I am sure fronts would be boltons too.i have both cars standing side by side all the time. I have't seen a single differnece so far in dampers and shocks so far. But i have't fitted the front ones,so cant be sure.
Here are some posts i found.
https://www.crzforum.com/threads/wil...fit-crz.56634/
Some one is saying the tie rod mounting point is slighly different?(LOL)
https://www.fitfreak.net/forums/2nd-...-question.html
I have tried rear ones,why not you try front ones and report us?
Old Jan 31, 2021 | 09:39 PM
hmarkop's Avatar
Tie-rods?? Is there a misunderstanding here?
The tie-rods connect to the steering knuckle (I think) and not to the strut in any way.. I think
BTW, KYB makes front and rear dampers for the CRZ (presumably they match the OEM specs and are thus perfect OEM replacements at 1/4 the price.)
I haven't seen any other aftermarket companies make dampers for the CRZ.
Old Jan 31, 2021 | 09:41 PM
Yes i was too suprised to read that. Just shared what i found in that post. i think fronts will work fine for us too.
Old Jan 31, 2021 | 11:51 PM
oldyeller's Avatar
Do you have any idea how much this lowers the car? This would actually be a good alternative to coils/lowering springs for me depending on how much it lowers the car.
Old Feb 1, 2021 | 01:48 AM
I think it will be around 1 inch lower.
and i have not measured front ones,but both are stading alongside each other. I can jack them up(to take out any bias due to engine/car weight) and measure the strut / spring or some other heights,that will give some idea but will not be accurate as taking them out of car and measuring them
Old Feb 1, 2021 | 10:49 AM
Pyts's Avatar
I want to hug you. ive found rear springs on ebay, but no fronts yet. 😂 This has potential to be done within budget! Rear springs used going for 40 bucks.
Say, are the seats in the CRZ mounted the same/any more comfortable?
Old Feb 3, 2021 | 03:46 PM
vinn's Avatar
I found a lot of the suspension bits to be interchangeable when I did the refresh of my car...was pretty cool!
Old Feb 4, 2021 | 12:58 PM
Glad i could help.i have uploaded new pictures in my 1st post.check them out
Old Feb 6, 2021 | 11:24 AM
SSM_Jersey_Fit's Avatar
Front : 2.2kg/mm
Rear 3.4kg/mm
F1.7k
R 2.0k
Intresting find for sure.
Old Mar 15, 2021 | 01:18 AM
Can_It_Fit's Avatar
How does the ride feel over stock?
Old Mar 15, 2021 | 01:26 AM
Actually i forgot how stock one rided because i was on coilovers for last 4 years.but its definetely batter than coilovers(comfort wise) and its slightly stiffer than stock( if my memory serves me right)
bdogpot
Dec 10, 2012 02:45 AM
MichaelBrown
Aug 18, 2012 06:58 PM
ragingti
Car Shows, Events, and Racing
Aug 7, 2012 04:38 PM
2Legit2Fit
Sep 1, 2010 10:05 PM
Ciggy
Jan 12, 2010 09:03 AM
