CRZ Coilover Question?
Old Nov 11, 2012 | 12:36 PM
bdogpot's Avatar
Question CRZ Coilover Question?
I have read alot on coilovers and one thing that keeps popping up is that the CRZ ones are the same for the fit and vise verse. The only thing i need to watch out for is spring rates or lengths becasue the crz has a taller spring in the rear. So my question is, if I were to find soome coilovers made for the crz is it true that I could use them for the fit second gen? The ones I was looking at were the cusco zero 2e, so that way I could get the 2e motor connects and cabin adjuster. Im in a wheel chair so adjusting settings would some what of a difficult task. Allowing me to change setting inside of the car would open up so much to me for this car. Unless some one knows of a kit all ready for the fit that allows this to be done. Im open to suggestions. Remember, Im in a wheel chair and would like to be able to elctricly adjust the dampening settings.
Old Nov 11, 2012 | 01:20 PM
1SickVeilsideZ's Avatar
They should work, a friend of mine got some BC coilovers for his fit from another friend that had them on his CRZ. They bolted right up.
Old Nov 11, 2012 | 01:28 PM
Wanderer.'s Avatar
From quick research apparently this guy has Cusco Zero 2e on his GE8, I didn't find anything specifically marked for the Fit/Jazz so i'd assume he used the CRZ ones?
Unofficial Honda FIT Forums - View Profile: Levinson-Durbin
Maybe shoot a PM over about fitment?
Old Dec 9, 2012 | 06:16 AM
555sexydrive's Avatar
Not exactly the same, the tie-rod mounting point is slightly different. Hayashi-San of Toda checked specifically for me when I asked since he has sussy for the CR-Z and not the GE8.
Old Dec 9, 2012 | 12:08 PM
Goobers's Avatar
couldn't you just swap in an adjustable tie rod?
Old Dec 10, 2012 | 02:45 AM
Yes I suppose. Not sure if it is just higher or lower between the 2 or just located differently altogether. Hayashi-San just said it wasn't compatible off the shelf.
ragingti
Car Shows, Events, and Racing
Aug 7, 2012 04:38 PM
vwli
Sep 1, 2011 10:55 PM
Tofuman
18
Sep 8, 2010 03:44 PM
pcs17
Aug 22, 2010 07:13 PM
Ciggy
Jan 12, 2010 09:03 AM
