Sponsored by:
Sponsored by: CARiD
Mudguards for Gen2
Old Mar 4, 2021 | 09:35 AM
nik danger's Avatar
Mudguards for Gen2
G'Mornin!
Need mudguards for my '12 Fit.
Tried searching for OEM or aftermarket, no results. I did see some apparently made for Accords(?) that came up when I punched in Fit.
Anyone know of any mudguards to fit my Fit?
Would like molded guards and not flat guards.
Nik
Old Mar 4, 2021 | 10:29 PM
Red 05's Avatar
If you have the sport model I'm reasonably sure the side skirts have to come off for the mudflap to fit properly.
Old Dec 6, 2022 | 07:25 PM
KrautBurner's Avatar
Carbon guards
https://thecarbonguards.com
the website doesn’t show the Honda Fit
but I had messaged them a while back, They do have them for us
Old Dec 10, 2022 | 06:00 AM
nik danger's Avatar
mudguards for Gen.2
Just checked carbonguard's website. I saw no listing for any Honda Fit, let alone a Gen.2
Perhaps one would need to call them.
Old Dec 12, 2022 | 09:38 AM
NWCH's Avatar
Searching on google owns this post. Took me all of 3 seconds to find these...
https://www.hondapartsnow.com/oem-ho...mud_flaps.html
Old Dec 14, 2022 | 06:13 PM
nik danger's Avatar
Aren't you something, NWCH! You the 'net searchin rocket man.
Old Dec 14, 2022 | 08:26 PM
GrE8_Fit's Avatar
Base only, right?
Old Dec 15, 2022 | 02:38 PM
like I said,
you need to reach out to them, they arent listed on the website
Old Dec 22, 2022 | 08:06 AM
jonshonda's Avatar
I am temped to buy the oem set of 4 and see if there would be anything left of the front ones after trimming for the additional body work.
Old Dec 23, 2022 | 09:56 AM
NWCH's Avatar
Originally Posted by GrE8_Fit
Base only, right?
Correct. Or you can trim or modify the standard guards to fit the Sport models.
Old Dec 27, 2022 | 07:07 AM
jonshonda's Avatar
I have searched around but haven't had any luck finding info on this. Are you aware of any pics or info on what the front guards would look like after they have been trimmed to fit?
Old Dec 27, 2022 | 08:36 AM
NWCH's Avatar
A local guy did it to his and it looks fine. If that is the look you are going for. He isn't a member here though.
Old Dec 27, 2022 | 08:41 AM
jonshonda's Avatar
Well that doesn't do me any good!! haha
It's not so much a look, as it is a winter in Wisconsin desire!
Old Jan 17, 2023 | 07:54 PM
Yetchtoo's Avatar
2013 Fit Sport. I have modified the front splash guards to fit nicely. Took a bit of work; Dremel tool, heat gun, sanding, and 2 sided industrial type tape. You do not have to remove the rocker-panel but you do have to trim the guards some. The rears fit properly as is. Part # 08P00-TK6-100, https://www.hondapartsconnection.com...et-08p00tk6100.
Mike
Old Jan 18, 2023 | 09:02 AM
jonshonda's Avatar
Mike
Interesting. I figured they would fit with some cutting. Do you have any pics of them installed, or them off the car and trimmed? It seems like the front 2/3 of the Fit stays much cleaner then the rear 1/3. I would be curious to see if that changes by adding mud guards.
Old Jan 19, 2023 | 05:32 PM
Yetchtoo's Avatar
Mud guards
Old Jan 19, 2023 | 05:42 PM
Yetchtoo's Avatar
Probably more for looks than functionality for the fronts.
Old Jan 19, 2023 | 09:30 PM
GrE8_Fit's Avatar
Wow, that's not bad! Well done.
Old Jan 20, 2023 | 08:19 AM
jonshonda's Avatar
Yeah I figured there was a reason honda didn't provide mud guards, and guessing the ground effects cover most of the area a mud flap would.
That did turn out really good! Gotta love the white/black contrast...thanks for sharing!!
I have a Tidewater Blue Metallic, and feel like I would need to paint match the rears for sure, as black isn't a great contrasting color for the TBM.
Old Jan 21, 2023 | 12:18 PM
Yetchtoo's Avatar
I would say that the color is really a charcoal like rubbery surface, and I would not paint them. Think the contrast would look good on any color.
