Tire pressure when carrying weight??
Old Apr 15, 2021 | 12:48 AM
azopelnut's Avatar
I am making a 200-mile trip tomorrow morning in my 2015 Honda Fit and carrying about 700 lb counting my own weight. Should I increase the PSI in my tires? If so what would you recommend?
Old Apr 15, 2021 | 10:28 AM
NWCH's Avatar
No just keep the tires at the manufacturer PSI rating for best results.
Old Apr 15, 2021 | 01:08 PM
Brain Champagne's Avatar
No. Tire pressure should be the same.
Old Apr 16, 2021 | 08:31 AM
Azuki's Avatar
Originally Posted by hotkey
700 lbs. is not a lot. That's like, what, about 4 adults? If I remember correctly, you may add ~4-6 psi. But keep it under 12 psi of max tire pressure.
Something like that.
I think this is the best answer. But there’s not really any issue keeping the tires at normal pressure for just one or two trips
Old Jul 26, 2021 | 11:49 PM
nomenclator's Avatar
Actually, 700 pounds is a lot. The maximum load is 850. If my hatch area does not have a lot of weight I will make the rear tires a pound or 2 less than the front. With a lot of weight, I'll make them the same. The spec for 2015 listed in my owners manual is 33 front 33 rear but I with a light load I fill to 35 front 34 rear. When I check the pressure after 2 months it will be down about 3 pounds in each tire. So 32 front 31 rear, or even less. So the average pressure over 2 months will be close to the recommendation. Always check when the tires are cool. Tires facing the sun will get very warm, and gain about 2 psi, so check in the morning, If Ifill the tires in the morning when it is 70 degrees F outside, they will lose about 2 pounds if the temperature drops to about 20 degrees F. They will gain 2 pounds when they feel warm, on a long road trip.
daddyscooltv
17
Nov 1, 2022 04:41 PM
azopelnut
Apr 15, 2021 12:32 AM
japspeed
Apr 11, 2014 09:29 AM
Len1
Sep 11, 2009 07:17 PM
RichXKU
Sep 29, 2008 07:26 AM
