Winter Tire Sizes
Old Aug 12, 2021 | 01:13 PM
veazer's Avatar
Winter Tire Sizes
I've got a 2015 fit and 6 or 7 years ago I bought a set of 185/70R14 winter tires and wheels from Tire Rack. Now I need new ones and I'm not sure if it makes sense to swap the 185/70R14's for a set of 175/70R14's, or stick with the 185's?
The oem all season size is 185/60r15, so the 175/70R14s are a closer match for overall diameter (0.1" smaller), but I don't mind the slightly larger (0.5") 185/70R14s I had previously. Will the 175s be any better in the snow or anything or should I keep the size the same and get another set?
They both say they can fit a 6" rim.
Old Aug 12, 2021 | 01:54 PM
For snow narrower is better
Old Aug 12, 2021 | 02:03 PM
Breezer's Avatar
These tires are so skinny alread, the little tiny bit of extra width the 185s offer, would seem to be a good thing to me. That extra sidewall height of the 70 probably helps your ride as well, if they didn't rub great.
Old Aug 18, 2021 | 12:25 PM
NWCH's Avatar
I use the same size tires. Just winter spec versions. Studs are nice if you live in the deeper areas.
ieandro
Nov 14, 2018 10:17 PM
FitfulKenny
Sep 27, 2015 05:03 PM
YWGjets
Nov 3, 2011 03:32 PM
FitCanada_Girl
Dec 12, 2009 08:19 PM
YeeFit
Aug 30, 2007 08:36 AM
