Hot honda fit
Old Sep 29, 2021 | 06:35 PM
daver721's Avatar
Hot honda fit
Does anyone have any idea how hard it would be for shade tree mechanic to replace a head gasket on a 2008 Honda Fit I seem to have gotten it hot last night and it hasn't been right since. It's trying to die at intersections and just doesn't run right,plus a loss of what little power it had... any advice?
Old Oct 7, 2021 | 12:12 PM
john21031's Avatar
You may have 20 reasons for the symptoms and dozens of different combinations there of, with dozens of different consequence scenarios.
You have to start with proper diagnosis... compression check, leak down test, pressurize the cooling system, etc...
If the damage to the engine is done as a result of overheating (btw why did it overheat in the first place), then you may have also warped the cylinder head and just replacing the head gasket is not enough.
Sounds like you need to take your car to a mechanic.
Old Dec 18, 2021 | 04:21 PM
joshuadsauceda's Avatar
Always good advice to start with in this situation. I second this notion.
phenoyz
May 17, 2015 01:37 PM
magdalena
Aug 17, 2012 04:49 PM
QuickGD3
17
Jun 30, 2008 10:39 PM
Cat
Oct 3, 2007 06:29 PM
FondaFit
Jul 18, 2006 02:53 PM
