2019 Honda Fit Ground CLearance
Hello - new member here and thanks for answering all my questions; I have a 2019 CVT Fit which supposedly has 4.4 inches of ground clearance. I'm having one of those buyer's remorse moments b/c I had a 2005 Corolla that was a beast in the snow and went over everything. And I mean everything - it has 5.7 inches of ground clearance and I'm now a little put back by the idea that the Fit won't go over; sandy roads on the cape, dirt roads near campsites, roots, rocks, etc that the Corolla happily ate for its noon-day meal. Any thoughts? Should I have gotten a Corolla IM which as similar ground clearance? Can a 2019 Fit be raised?
Thanks!
Thanks!
I feel your pain OP. My Ford Focus was fantastic for ride height (rest of the car was a total POS
). Not only could it clear snow drift etc with ease, but I also didn't have to raise it to do oil/filter changes.
OTOH my Fit needs to be raised for any under-car maintenance.
Honda designs these cars close to the ground not only for handling, but for improved fuel efficiency thru aerodynamics - my educated guess.
Ya sure, you can rise it. I've seen threads on here where others have raised theirs.
). Not only could it clear snow drift etc with ease, but I also didn't have to raise it to do oil/filter changes.OTOH my Fit needs to be raised for any under-car maintenance.
Thanks
I live in florida now, but my 2015 Fit never bothered me at all from snow clearance when I lived in Maryland. However, I have damaged the plastic pan under the front when I went over low curb I didn't see. And the repair shop patched the connections. Till I did the same thing again, and they replaced the plastic tray. Now I'm more careful.
My large plastic tray got torn off in the winter. I have removed it because it fell down again after the attempted repair. My car is treated yearly with Krown Rust so I am not concerned with exposure to the elements.
I literally hit a turtle once with the bottom of my fit. apparently, it was just the bottom cover, because it survived. I can't tell you how many times I have straddled road kill only to hear the dreaded "thump".
ausgat
Jan 5, 2020 08:05 AM
basstoy
Apr 16, 2019 05:32 AM
