How to safely remove a 30A fuse?
Old Oct 19, 2022 | 06:49 PM
smetzger's Avatar
Blower fan is not coming on. I figure it is probably the blower motor resistor. But I wanted to check the fuse first.
The fuse is number 57 and is one of the flat 30A ones.
How do you remove it? Just pry it out very carefully with a screwdriver or is there a better way?
Old Oct 20, 2022 | 06:31 AM
Frenzal's Avatar
Pull it out with needle nose pliers?
Old Oct 20, 2022 | 08:35 AM
Ultrawolf's Avatar
There are all-plastic fuse pullers that come in different sizes for different type fuses. That's the safest thing to use since there's no risk of any metal shorting something out. You can check an auto parts store or an online source like Amazon.
Actually, look inside the fuse box or the back of the lid. There may be a puller clipped in there.
Old Oct 25, 2022 | 01:35 PM
Breezer's Avatar
I just pull them with my fingers.
It should be what they call the mini type if it needs replacement.
tjkelman
Oct 23, 2022 07:08 PM
oneder101
Jun 15, 2015 05:03 AM
Trogdor!
Sep 17, 2010 04:33 PM
sickGE
Apr 7, 2010 08:22 AM
fit2bcrazed
Nov 30, 2007 03:43 PM
