GE8 5 Lug Rear Disk
Old Oct 22, 2023 | 10:33 AM
myblackhatch's Avatar
GE8 5 Lug Rear Disk
Rear disk just looks so good compared to drums
Close up
Front angle of wheels
CR-Z Torsion Bar Installed
CR-Z Hubs, Calipers and Rotors. Extended lungs to match the front
New Bushings
Used a front chassis bar as a pull point for my ratchet strap.
Just wrapped it around the torsion bar.
Fit Steel LCA vs CR-Z Aluminum LCA
CR-Z Brakes - Rotors are incorrect and don't fit
CR-Z 5 Lug Spindle Conversion on the Fit knuckle
Old Nov 15, 2023 | 12:12 AM
USDM's Avatar
Looks good! Good call on going with extended wheel studs as well. Mind clarifying a few things?
What rear brake lines and e-brake cables did you use?
You mentioned the front rotors are incorrect and don't fit? Did you receive incorrect parts or do CR-Z front brakes not work for the front 5-lug conversion?
Thanks.
Edit: I came across your build thread (good stuff) and wanted to update/edit my post. I saw that you're using a 3 mm spacer behind the rotor to help center it with the front CR-Z brakes. Still curious about rear e-brake cables and brake lines. I saw that you ordered some Fit RS e-brake cables?
myblackhatch
Jan 12, 2026 02:35 PM
StaticGe8Nyc
Dec 11, 2017 09:05 AM
SpoonFitGD3
Feb 8, 2011 11:35 AM
bigu
Oct 1, 2009 09:29 PM
qkslvrtypes
Oct 27, 2008 02:26 PM
