Looking for an answer if USDM GD3 Fit springs fit UK Jazz GD1
Old Feb 2, 2024 | 01:53 PM
B520pGD1's Avatar
I have purchased a set of Tein S.Tech for GD3 springs.
as the model listed on the Box is GD3 07-08 and search them on the Tein site they are for US and apparently identical to the other SKU available in other regions.
Not opened the box yet and now not sure if they will Fit as I'm reading that USDM shocks on the front are shorter.
Want some reassurance if they fit on a UK 2005 GD1
Looked on UK forums but not much in the Mod scene going on and just receiving unhelpful replies not seen any posts on here around the UK Jazz.
The part number is SKB36-S3B00 if it helps
I've read the sticky thread that lists Tein that fit the GD1 and GD3 but is a different part number I can't find info on and links are broken as its a pretty old post.
https://www.fitfreak.net/forums/fit-suspension-brake-modifications/2504-honda-jazz-fit-suspension-thread.html
GD1 and GD3: Part number SKA04-S1B00 - Springrate Front/Rear: ~ 2.2k / ~ 2.5k - Lowering Front / Rear: -40mm / -35mm - Retail Price: 250 USD
"The Honda Jazz/Fit suspension system is a fairly simple one. Both the GD1 and thd GD3 suspensions use the same components, but the GD3 (The VTi and VTi-S) have slightly stiffer springrates."
Thanks for the help in advance and hope someone can help. Otherwise I might have to return them and rethink.,😔
ivanh
Dec 8, 2010 12:44 PM
MikeM_version2
Nov 26, 2008 01:02 PM
Darkstars
Feb 25, 2008 05:28 AM
JDM_FIT
Aug 11, 2006 03:49 PM
the_saint
Feb 7, 2006 10:03 PM
