If you ever forget to reconnect the GK Fit's MAF Sensor
Old Apr 11, 2024 | 04:55 PM
Jazu's Avatar
The fastest way to reset your GK Fit's MAP sensor after leaving it unplugged after an engine air filter change is to: (1) reconnect the MAF sensor with the engine off, (2) pull the NEG - battery for 10 minutes (clean the connection and put more dielectric grease on the connection, (3) reconnect the battery using a 10mm socket, and (4) drive. Otherwise after multiple drive cycles P0102 and P0113 will persist until cleared and you'll have a Christmas tree color extravaganza on the dashboard: Steering, DSC, tire pressure, and and solid Check Engine (MIL) lights stay lit.
Driving the car with the MAF sensor disconnected (in the driveway) felt like the stumblings of an old carbureted Chevrolet Cavalier with 100K miles.
Now you know.
Old Apr 11, 2024 | 10:02 PM
howarejew's Avatar
You don't need to unplug it to change the air filter
damoaten
Aug 21, 2024 04:17 AM
Jerry Mt
Jul 11, 2020 05:45 PM
Myxalplyx
42
Apr 29, 2016 04:38 PM
thc888
Feb 8, 2013 09:27 PM
Fitinside
Mar 26, 2007 09:54 PM
