Code P0847 2012 Fit
Code P0847 2012 Fit
My daughters car a 2012 Honda Fit 100k just threw a code P0847 ECU 2 I read it with code reader it said Trans Fluid Press/Sensor Switch B Circuit Low. It looks like there are 2 sensors does anyone know which on it is couldn't tell by the diagram I found on here
P0847 Code
I replaced the fwd sensor 28600-RG5-004 that I bought off Amazon, cleared the code and took it for a test drive immediately check engine light and flashing D Read the code and it said P0848 which is the high limit. Do you think it's a bad sensor? Put the old one back in cleared the code and it didn't come back on
mike420
May 20, 2021 05:10 PM
