Headlight BUlbs?
Old Oct 26, 2024 | 12:06 PM
SilverEX15's Avatar
Headlight BUlbs?
Any recommendations for brighter headlight bulbs? I don't want LED or HID, and I'd like something that will last more than a month.
Let the recommending begin!
Old Oct 26, 2024 | 10:14 PM
2Rismo2's Avatar
I would not recommend the PIAA Xtreme. They last about a year and burned out. First set was replaced under warranty. 2nd set didn't make it a year and I gave up on them. I've been running LEDs for years without issues since.
Old Oct 27, 2024 | 10:41 AM
SilverEX15's Avatar
Thanks.
When you say LEDSs, you mean the bulbs you insert into standard headlight sockets? Did you have to re-adjust them?
Any recommendations for one brand or model over another?
Old Oct 28, 2024 | 12:46 AM
Chitown Fit's Avatar
LED Lights.
I also bought a set of the PIAA Xtreme White light bulbs.
They are brighter than the Sylvania Silverstars. Unfortunately like already stated they burn out in less than a year.
Check the LED Light Bulb thread for my answer to that thread.
Old Oct 29, 2024 | 06:46 PM
2Rismo2's Avatar
Thanks.
Yes there were drop in, not a projector retrofit. I used these lights and pretty much run them on the entire time the car is on. I figure the extra visibility is worth whatever reduction in life of the bulb. 6 years later it's still working great. I did have to aim the passenger side a bit lower after, but that's easy. Beam pattern looks good and no one is flashing high beams at me so I guess I'm not blinding them
https://www.superbrightleds.com/h4-l...set-cool-white
My yellow LED fog lights are 7 years old: NOKYA NOK7623 Pro Halogen Hyper Yellow H8 35 Watt 2500K Light Bulb https://a.co/d/6b5wAKO
Backup bulbs are also LED and also 7 years old,I didn't have the link for those anymore.
I recently did switchback LED for my turn signals and other than the faster flashing, I really like them. So now my front turn signals are running white until you turn them on, and then the flash yellow then turn back to white after the turn is complete.
Amazon Amazon
Old Nov 1, 2024 | 07:31 AM
SilverEX15's Avatar
I recently did switchback LED for my turn signals and other than the faster flashing, I really like them. So now my front turn signals are running white until you turn them on, and then the flash yellow then turn back to white after the turn is complete. https://www.amazon.com/dp/B07JC2Z3TK...p_mob_ap_share
Excellent reply! Thanks!
"I recently did switchback LED..." What exactly did you mean by that?
Old Nov 1, 2024 | 07:27 PM
2Rismo2's Avatar
Originally Posted by 2Rismo2;1486489
So now my front turn signals are running white until you turn them on, and then the flash yellow then turn back to white after the turn is complete. [url
https://www.amazon.com/dp/B07JC2Z3TK?ref=ppx_pop_mob_ap_share[/url]
If you click the Amazon link, you'll see some videos. Instead of an orange/yellow running light by the headlight, it's running white. Then when you turn to signal it flashes yellow. After the turn is over it goes back to running white.
Old Nov 2, 2024 | 11:22 AM
wasserball's Avatar
I tried plug and play LED. The OEM lens is not designed for them, therefore, the broadcasted light is not where you want them to be on the road. I had to return them for a refund. Maybe someone has found a plug and play LED bulb that actually perform satisfactory. In the end, I went to Sylvania Silverstar ULTRA 9003/H4. They are brighter than the OEM bults, but because they draw more power, mine only last maybe 2 years. I keep a replacement in the car if I have to replace them when I am on the road.
ASHNED1215
Dec 18, 2017 10:37 AM
typeszh
Jul 12, 2017 03:20 AM
emotionr
Apr 5, 2013 03:33 PM
Chazzlee
Dec 2, 2009 08:49 PM
Chikubi
Jun 2, 2006 03:19 PM
