Pulley for drive belt tensioner
Old Dec 31, 2024 | 04:05 PM
honda599's Avatar
Has anyone replaced just bearing on 2009 Sport drive belt tensioner pulley? Looking at obtaining size
Old Dec 31, 2024 | 04:30 PM
dwtaylorpdx's Avatar
Rock auto to get the whole pulley, the bearing will likely cost more and the pulley isnt really designed to have the bearing removed, when I swapped mine it looked like they swaged the bearing in to the pulley.
Old Jan 1, 2025 | 01:55 PM
Mister Coffee's Avatar
I bought a Serpentine Tensioner and a Serpentine Belt. Haven't installed them yet.
I like OEM parts, and I don't mind spending the money for them. Life is short. Shorter for some of us than for others.
Old Jan 2, 2025 | 01:22 AM
If I can get SK or FAG when bearings are involved I'm gold..
Old Jan 2, 2025 | 11:06 AM
GrE8_Fit's Avatar
I got this $14 Dayco pulley. Easy install.
https://www.rockauto.com/en/catalog/...r+pulley,10346
Old Jan 3, 2025 | 09:51 PM
honda599's Avatar
Drive belt pulley update
Usually I use genuine parts but in this case very expensive considering tensioner still fully functional, only issue is worn bearing. Above bearing SKF(Argentina made)from Lordco $9.50 Canadian plus taxes and easy to replace after removing assembly. Unable to locate NTN6203 LH original Japanese bearing. Current mileage 380,000kms original owner. Was pretty easy to do, all from the top. 40mm X 17mm X 12mm seals on both sides, high temp and rpm.
Old Jan 5, 2025 | 01:06 PM
@honda599 Thanks for following up. Let us know how everything goes down the road.
grommet
Apr 27, 2026 09:57 PM
Mister Coffee
Jul 13, 2024 06:17 PM
LeighOriana
May 25, 2022 09:45 AM
jilm
Apr 13, 2016 06:22 PM
lightyear22
Oct 1, 2014 07:47 AM
