2008 GD1 CVT jumps (feels like gear shift)
Old Feb 3, 2025 | 11:02 AM
17ezequiel's Avatar
Lately my 2008 GD1 CVT Fit (102.500 km currently) has been making this kind of "jump" when accelerating and/or going at a constant speed (does not happen when the gas pedal is not pressed). It feels like a transmission shift, which lasts a split second (like the car loses power but immediately gains power again). It's not very frequent though, it might not happen at all during one drive, or it might happen once or a couple of times.
I've had this car for nearly 3 years but it only started happening recently. CVT transmission fluid was changed 2 years ago when serviced at 90.000 km, spark plugs as well. Filters were changed quite recently with the 100.000 maintenance service.
Any ideas on what could be causing this issue?
Thanks!
Old Mar 22, 2025 | 03:25 AM
2015LXFIT's Avatar
Sounds like under load judder aka. your trans is dumping out internally. Stay away from the CVT. The frictional transfer of power vs a manual gearbox or even clutch/friction disk style is far less robust and even less forgiving than the latter 2. It is possible it's a solenoid/pressure related issue but generally it's the bands that wear moreso. Confirm with $$$$ code reader there may be a code stored in TCM.
Giorgi Jaghmaidze
Feb 29, 2016 01:13 PM
gpennino
Mar 21, 2015 10:21 AM
Ex-MA Hole
Aug 11, 2014 06:48 PM
agcat1981
Sep 9, 2010 08:05 PM
hogwylde
Dec 8, 2009 09:45 PM
